FS: hood / front upper strut bar
01-03 civic
Very used HP full race header (the one piece from exhaust manifold to cat). 60
rumor has it that it is for an auto only however it will fit on manuals with some trimming. I believe you have to trim the subframe. I had to go to an exhaust shop to cut the piping on the cat down just a bit because the header extended well beyond the flange. No modification has been done to the header itself. Has an o2 sensor on it, been awhile so it may or may not be good.
Blue carbon kevlar hood, doesn't have a name on it. no washer hole, pretty thin on the clear side but still shines. lightest cf hood i've owned. would recommend using hood pins. 200
Generic front upper strut bar. 20
i got no pics, rather you come check out the hood in person. located by 91 and 57.
Parts were off of my 02 coupe which was rear ended and totalled. race header was not installed at the time of accident.
Abe
Abe
GH04si
Apr 15, 2015 08:13 PM
