Need to change bearings
Old Feb 10, 2006
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
anyone know of a shop that is affordable. most likely im gonna buy the part and have them install. plus anyone how much will it cost?
Old Feb 10, 2006
Nodnero's Avatar
y0 kid, how far you willing to drive?
Old Feb 10, 2006
TuRtLE714's Avatar
that sentance scares me for some reason....where it be at anyways?
Old Feb 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
haha ... WHAT bearings?
wheel bearings, differential bearings, etc ?
Old Feb 10, 2006
TuRtLE714's Avatar
wheel bearings...sorry to mention
Old Feb 10, 2006
Nodnero's Avatar
Either ELA or Glendora
Old Feb 10, 2006
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
is your car making that clunking sound when you turn?
Old Feb 10, 2006
TuRtLE714's Avatar
yeh...at low speeds too. embarrassing cause it was loud as hell infront of people too.
Old Feb 10, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
haha i just got my bearing replaced a week ago. umm i know a place called City Tech auto umm i'll give you more about it later, it was pretty cheap considering
Old Feb 10, 2006
TuRtLE714's Avatar
please let me know i need to do asap and how much you paid to get done.
Old Feb 10, 2006
Ser1N's Avatar
EK Hatch
Ser1N is an unknown quantity at this point
thats what my car makes only when i break. Is that also wheel bearing issue?
i changed the pads and stuff but yah
Old Feb 10, 2006
04civic07's Avatar
okay i went to that City Tech Auto Repair, but it's in Rosemead/san gabriel, off the 10 sorta near 605 too, so i dunno if you wanna make that drive but the address is 8419 Garvey Ave, rosemead, ca 91770. opened m-sun 8-6. it was 120 for the shiny new bearing and labor. and it was only a 15 minute job. idunno how much other places are, but getting a bearing from honda costs about 120+ w/o labor....so yeah. btw: this is for ONE bearing. and if you're not sure which one it is, just lift one side and push the wheel in towards the struts and out towards .....out haha if it wiggles, that's the one. know which one, or else they charge 24 for diagnotic
But after that..... i never took the normal loudness of my car ever again. HATED that thumping noise. it sounded like i was riding on a train. Ser1n, that's probably just your pads and stuff. bearing sounds like that thumping when you're stopped behind a train X-ing while the train's going by. thats while your driving, but if it sounds like that when you're braking, your rotors are warped and bent. i had both happen
Old Feb 10, 2006
Ser1N's Avatar
EK Hatch
nevermind
Old Feb 10, 2006
evangelize's Avatar
evangelize is an unknown quantity at this point
dude, i have that cluncking sound too when i start my car and its pretty loud, and it also makes the sound when i shift gears and when reverse, does that mean my wheel bearings messed up too? i dont know what the problem is.. it pisses me off.. i thought it was my clutch being worned out or something... could someone tell me what my problems may be... thanks..
Old Feb 10, 2006
TuRtLE714's Avatar
okay i jacked-up the car and wiggle the side it was making noise and it doesnt wiggle. So wheel bearings is out the question. But i begin to spin the wheel and it makes a squeaking noise. My rotors need to be re-surfaced? or brakes? Cause when im on the road and it makes this noise, i break, the sound goes away.
Old Feb 10, 2006
04civic07's Avatar
if it sounds like trains going over a track as in thump thumpthump...yeah... could also be described like the sound of a flat tire being driven. like in the movies. but if it's more of a *erp erp erp* sound that is off and on, depending on wheter you are braking or not. then it's your rotors, they're probably warped.
anyways.... you said you hear squeaking noise when you spin the wheel. if it's a constant "squeak" with no break in the sound. then it's very likey that you just need to change your pads. well.... if it's coming front your front wheels (brakeshoes if it's in the rear) sooo.....
take the wheel off the car and turn the wheel (clockwise if it's your left side, counter clock if it's your right passenger side) so that you can see the side of the brake caliper. notice that there is a small peep hole in the ver dead middle and center of it. you should be able to see the brake disk sandwiched between the pads. if there is Less than 1/8 of an inch of pad left (i'm talking about the stuff that touches the rotors), then it's probably your pads. the noise is from this metal "rod" that is suppose to warn you when you should replace them (the squeaking)..... yup
just take it to a repair shop..dont ever go to dealers.
Old Feb 10, 2006
04civic07's Avatar
shoot double post, ignore
Old Feb 10, 2006
04civic07's Avatar
if youre talking about while the wheel is moving then has to do with your "brakes" in general. idont know whether you are talking about while stoped or moving haha. but if you hear a cluncking right when you start your engine it's somthing else.... specify
Old Feb 10, 2006
evangelize's Avatar
well, basically i hear a loud clunk sound right when i start my engine.. and when i reverse i hear constant clunking sound.. also, when i shift gear i hear it too... also, when im driving (1-3 gears) i let go of the gas, it i could hear the sound like crazy... all these sounds seems like its coming from my hood... im thinking it might be my spark plugs... but im not too sure, im a noob to these stuff so, please give me some ideas what might be the problem thanks...
Old Feb 11, 2006
04civic07's Avatar
hmmmm i'm not too good with engine diagnostics...yet hahah i help swaped an SR20det on my friend's 240sx...like 3 times but i am clueless when trying to find an engine problem..... maybe pop the hood and have someone start the car for you and see where i might be from. then have someone drive slowly reversed and forward to see that as well.???? just ideas, but idunno how smart that is. try asking boilermaker, after that take it to a shop ASAP haha sorry bro not good with that. could be as simple yet dangerous as a nut floating around in someplace, i've seen that in a starter. but yeah kinda gettin off topic
Old Feb 19, 2006
rEkKaShInObI's Avatar
Unsalvageable
im getting this problem now, i just started to notice it. i hear a clunking sound from the passenger side, and this only happens when i turn left, when i turn right its normal. suggestions?
Old Feb 19, 2006
putang inamo!!!
lol damn i thought i was the only one? i'm guessing it's the bearings? when i swapped out my ground control coils for the stock springs that's when it started making that thumping/clunking sound. it happens when i turn left/right or even hit a bump. i just got an alignment but when i turn hard left or right the alignment is ruined. for ex: i'm turning a hard left the steering stays to the left, in order for me to make it straight i have to turn the wheel hard right...........
Old Feb 19, 2006
TuRtLE714's Avatar
well mine was my brakes...changed up up wiht chase on sat. (thanks chase) and no more squeaking for me
Old Feb 19, 2006
04civic07's Avatar
not your bearings, something is wrong with your struts/shocks. might also be something loose, check your nuts and bolts. turn your wheel left see if there is something wrong with the strut, then turn to the right and look at the strut to see if anything wrong.
Old Feb 19, 2006
putang inamo!!!
^ I don't think anything is loose. Everything is tightend. Iv'e been driving my car like this for almost 2 years.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
The Big Dutch
Jun 9, 2015 07:49 PM
Jigee
May 9, 2015 11:18 AM
oqjoi
Transmission
May 6, 2015 06:27 PM
dosmastr
May 5, 2015 12:19 PM
