CV boot question
Old Jan 17, 2006
MBison's Avatar
MBison is just really niceMBison is just really niceMBison is just really niceMBison is just really nice
CV boot question
hey guys. i have a cv boot that is torn (driver side) and i already bought a new boot kit to get that replaced. is it enough to just replace the boot or should i replace the whole axle (i really dont want to spend more money on this)? let me know what u know.
Old Jan 17, 2006
LiKEaFeRiO's Avatar
You should be able to just replace the cv boot as long as there isn't any damage to the axle.
Try to get rid of all the old grease and fill it up with new fresh grease.
Old Jan 17, 2006
MBison's Avatar
hey bro. how do i check whether the axle aint damaged or not? do u know how to replace the boot?
Old Jan 17, 2006
LiKEaFeRiO's Avatar
When you wipe off all the grease you can just tell if there may be damage.
But usually if there is noticeable damage your car would be grounded right now.
I know how to replace the boot.
I wouldn't recommend you do it at home unless you have the right tools.
Sometimes its a bitch getting the axle off and back on.
Old Jan 17, 2006
MBison's Avatar
maybe we could meet sometime in february and if you could help me out with that, that'd be great. lemme know if u could make it.
Old Jan 18, 2006
LiKEaFeRiO's Avatar
Its not that hard...just fustrating when things won't come apart.
Follow the DIY Spring Install to take apart the front.
Go to Kragen's and borrow a ball joint separator kit to remove the tie rod.
Take off the axle and remove the boot.
Replace boot and fill with grease.
Put it back together.
Not detailed but basic directions.
PM me in Feb and I'll see if I can help you.
Old Jan 18, 2006
MBison's Avatar
right on i will try to do it myself first.
Old Jan 18, 2006
dru106's Avatar
ThE CoRRupToR
You also need an impact gun to remove the axle nut. I would just replace the whole axle cuz its easier and once its torn the dirt is already in the grease so its no good.......
Old Jan 18, 2006
Touge Whore's Avatar
K-DUB
Touge Whore is an unknown quantity at this point
You should be fine just filling the new CV boot with fresh grease and replacing the older boot. Unless you are showing the signs of damaged axles, such as "clicking" while turning, you will be fine with only a boot replacement. Just visually inspect it, you will be able to notice most damages, if any.
Old Jan 18, 2006
MBison's Avatar
thanks for the advices
tuvok
Sep 25, 2015 03:13 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
exiled1
Aug 8, 2015 06:09 PM
Nikipedia
Jul 28, 2015 10:50 PM
