immobilizer for 2001
Old Oct 14, 2005
blue_dlb's Avatar
blue_dlb is an unknown quantity at this point
I've done searches but couldn't find the answer. I read that the immobilizer came in civic starting 2001. The immobilizer chip is suppose to be on our keys right but the 2001 civic keys look to be too small to hold a chip inside. The 2001 and the 2004 civic keys look different. The 2004 civic keys looks like it can hold a chip inside of it. Is it just different technology? Or is it because the 2001 civic doesn't have an immobilizer??
Old Oct 15, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
the 2001 vic has a immobilizer
Old Oct 15, 2005
dj02's Avatar
all of them come with it. you'd be suprised how small a micro chip can be.
Old Oct 15, 2005
CraigW's Avatar
You should have a sticker in the (front) side windows ?? If they had the warning sticker then.
Old Oct 15, 2005
blue_dlb's Avatar
Well let's just say you took ur key to homedepot or a lock smith to have it cut, will you be able to start the engine with that key? If you can then the chip is not placed in the key. So the immobilizer not being on the key is not as an efficent design as the newer ones.
Old Oct 15, 2005
7thGenerasianCivic's Avatar
7thgens have immobilizer chip in them, It's a very small chip that sends out a frequency to the ignition. If you have a key duplicated at home depot it will NOT start the car, but will probably open doors, trunk, etc.
Old Oct 15, 2005
LiKEaFeRiO's Avatar
Yes the copied key can open everything but it will not start the car.
The engine will turn but doesn't start up.
Old Oct 15, 2005
blue_dlb's Avatar
Has someone personally tested it out?
Old Oct 15, 2005
Yes. I had my ignition changed and I only had one key with me at the dealer. So I have 1 key that works and two that don't. There is a bypass or way around it. But I will not post here. Do you have a key that does not have a chip and it starts the car?
Old Oct 16, 2005
TemjinX2's Avatar
The immobilizer is in the car and the keys have transponders. The 01-02 have a male edge key and i know the 04-05 keys are female edged keys therefore are a little more difficult to copy. I'm not sure about the 03 keys.
Yes the immobilizer really works. I had the dealership guy tie my immobilizer to my alarm so if my alarm goes off then the car will not start even with the real key. If you plug a copied key with no transponder then the car will not turn over. Does this make your 7th gen theif proof? NO, but it makes it more difficult to steal your car then the 6th gen. The 6th gen all you have to do is jack in a flat head screw driver and turn the ignition and the car would turn on.
Old Oct 16, 2005
earlier ones look at the edge of the key
Old Oct 16, 2005
blue_dlb's Avatar
Thanks every one!!!
No, i only have one key and i need to make spares so i'm wondering if i can just make them at homedepot but it doesn't sound like i can.
Old Oct 16, 2005
However you can make them at a Honda dealership for about $50+ a piece. hahaha
Munzy
21
Oct 7, 2015 07:48 AM
thatcham
Sep 30, 2015 08:28 AM
raymondxcho
Sep 29, 2015 09:00 PM
260000milesgoal
Sep 25, 2015 07:41 PM
blward6
Sep 16, 2015 05:32 PM
