Diy Lambo Hinges....
Old Feb 29, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
ok i was really board so I'll post this, Ive been looking for a long time to cut the cost on a cool idea but hella expensive mod for some strange reason...but here we go
basicly all you need is the hing, the rest can be bought from the internet with a few good google surches...
This is street dreams hing kit as you can see it comes with the shocks and mounting hrd ware for about 750 bucks, but dont be fulled, this is not a bolt in kit, this kit was ment to be welded in. but the idea for a bolt in design is there..you just need to know how to tweek it...
now you can buy just the hinges for about $350 from street dreams and start your little project
once you have the hinges you need to find a way to mount them, this is where you need a welder to fab up some triangle mounting plates to kick the hing off at 45 degree angle from the fender wall (top pic in to btm img) and door(btm pic in the btm img) ..like so ( taken from steet dreams site)
as you can see the hing sit's in the middle between the two tirangle Pc's, once you have someone fabricat the triangls the wrk is 75 % complete...cuz all you would need to do is drill the holes out in the triangle plates to mount to the stock locations( door and fender) useing the stock bolts...Now door should have the swinging upward motion..
Time for the shock setup
Basicly you can mount the shock pretty much any where as long as it has nothing obstructing its path to full extension and close.
Using street dreams designs, I would go with the first Pic design you see in the Image above and heres how you acheive that... you basicly need to fab an L bracket to hold the studed ball mount to connect to the swing arm on the door side ( thats the part in between the two hinges that keep the door from opening so far) ...here the studded ball mount whick you can buy from street dreams for about $35 bucks..and you can see where that goes in the first pic of streetdreams designs on the door,,
all thats left now is to fab a metal bracket to hold the other studed ball mount of the shock to the btm portion of the fender well and you do that by makeing a plate and welding on the studed ball mount to it and drilling out the wholes to bolt up to the stock location..and there you have it..
shocks come in different pressures, the most u would need is 120 lbs shock to lift the door..but the cool thing is that if you got one at 200 lbs the door would open and rise automaticlly with the use of a door popper and siliniod...so if you had a extra out put on your car alarm when hit the btn to unlock the door...it would not only unlock but open and rise up and you can do that for both doors..
autoloc has a simular design bolt on kit but for around 1500 bucks...for that you can buy the decah kit, which i must say by far is the best design out there
Old Mar 1, 2004
VNlilMAN's Avatar
The Standard One
have you done it yet?
Old Mar 1, 2004
KaZeLL's Avatar
pics r acting funny dont know why but go to my ride gall and click on img's if you can view them...they sould pop on after that
Old Mar 1, 2004
KaZeLL's Avatar
well i dont have my car as of yet ..still at honda...but after the two shows HIN and forbiden Fantasys Im going to try and make the brakets for us...putting the final cost of the whole thing at about 600 bucks...
Old Mar 2, 2004
KaZeLL's Avatar
this is the installation manual for the decah kit as you can see nothing is really just bolt on, you still have to do some trimming to your car in two parts on one side of each door...the fender skin needs to be rolled and the top frame metal so the hing can rotate...
Old Mar 2, 2004
KaZeLL's Avatar
Old Mar 2, 2004
KaZeLL's Avatar
Old Mar 2, 2004
KaZeLL's Avatar
Old Mar 2, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
nice but damn look hard,
Old Mar 2, 2004
Stephon314's Avatar
Stephon314 is an unknown quantity at this point
Thanks a lot for provding this information. Doesn't seem too hard to me cuz I think it's similar to the idea of the trunk shocks DIY from Grey. You just have to measure it right, drill holes, and some other modifications as well. Can't believe they sell these kits for $1600...
Old Mar 2, 2004
DaZeD's Avatar
Don't Hate. Just Envy.
if its 600 bucks ill do it
Old Mar 2, 2004
7thGenerasianCivic's Avatar
dang... bump
Old Mar 10, 2004
RedDragon333's Avatar
for 6 bills i would do it. Kep me posted
Old Mar 11, 2004
Rudeboy's Avatar
Rudeboy is an unknown quantity at this point
Wow thats hot kazell you got some pretty cool I ideas I would want to get that Done on my G35 but I wouldn't want it to be permanent have you seen anything like this For my car?
Ziggy1999
Oct 15, 2015 07:56 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
henrytn
Aug 11, 2015 10:01 PM
