Data Logging
Old Sep 14, 2007
dfminc's Avatar
dfminc is an unknown quantity at this point
Data Logging
What is a good data logging setup for improving driving? I want to be able to log my autocross runs but I don't know anything about data logging systems.
Old Sep 14, 2007
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
Re: Data Logging
mmmm, The only real way to data log racing is to get a system that has onboard dataloging such as the new K-pro. If not then it is difficult to log because you would have to have the CP hooked up while driving.
Honestly for autox and even track days the only way to get the most out of logging is to have a video that you can follow as you log things. I would watch throttle, rmps, gear, and mph. really those are the only thing on K-pro that I think would assist in making you a better driver, and those things will not do much.
The best way to learn is through seat time, and trial and error. One of the best peices of advice that i was ever given is the 100% rule:
you have 100% to brake, throttle, turn, or a combination of the three. If you are turning in 35% you should have released your throttle to 65%, if you are comming out of a corner and are at 45% steering lock then you should be at 55% throttle. If you are trail braking a corner and are at 35% steering lock you should be at 65% brake and releasing only as much brake as you are willing to turn and turning as much as you are willing to brake. With our cars (especially when they are making a crap ton more hp than they should) it is important to find the link between the steering wheel and the gas pedal. As you turn in you release the gas, as you straighten the wheel you ease on the gas, it should be very proportionate.
OptimisticWay
46
Oct 15, 2015 02:16 PM
Bruce2
Sep 21, 2015 08:01 PM
Donahue
Sep 8, 2015 09:00 AM
JoeB16
Sep 6, 2002 10:33 PM
RX7T2
Mar 4, 2002 06:13 AM
