So i was just cruzin...
Old Aug 5, 2006
  #31
SLO REX's Avatar
250+ awhp Stage 2
Haha 15.8...Man I love AWD turbo.
Old Aug 5, 2006
  #32
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
I am telling you 201 whp is enough in these little cars to go mid 13s, which is plenty for me. It is just that you get use to it after a while.
Old Aug 29, 2006
  #33
05civic_kid's Avatar
05civic_kid is an unknown quantity at this point
wait wouldnt bigger rims just make it harder to spin tha tires since its bigger n more mass. iv always heard smaller is better for acceleration. can sumone PLEASE explain to me.
Old Aug 29, 2006
  #34
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
^^ well with all the extra power he is making he is spinning his tires like crazy and he needs more traction instead of spinning tires. it would be better to have the tires gripping the floor rather than spinning all over. old tread.
Old Aug 29, 2006
  #35
ic that dose make sense either way big rims or not he'd still make me look like im sittin still lol.
Old Aug 29, 2006
  #36
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Actually i think i would make it look like you put your car in reverse and hit the gas.
Old Aug 29, 2006
  #37
LOL yea but id still run ya just hear ur rocketship take off! i was playin wit a TSX today on sum curvy back roads, tha only reason i stayed ahead is i could beat him outta tha corners wit my eibachs. but on tha straights he would run up on my *** but to scared to pass lol. but hey even if he had beat me it was fun!
Old Aug 30, 2006
  #38
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Here's my contribution to this thread.....
It's called inertia. If you take string with a weight on the end and spin it, it'll go pretty fast, right? While you're spinning it, move your hand up on the string and what happens? It spins faster, right? A circle with a smaller diameter will spin faster with much less force than a circle with a larger diameter. However, this will be offset by another property. If you take a 15 inch wheel and attach it to an axle that makes one revolution, the vehicle will have travelled the circumference of that wheel. If you put on an 18 inch wheel and have that axle do that same one revolution, the car will have travelled farther by the difference in circumference of the 2 wheels. So what you need to do is put the wheel/tire diameter and weight into a formula to figure out the best ratio to get you the farthest in the shortest amount of time.
More importantly, if you're looking for a better launch, what you want is more contact with the ground, not a larger wheel. Simply a wider wheel/tire combination will achieve this along with something with less of a tread pattern on it, preferably no tread pattern at all (slicks). You may also want to factor in the temperature/consistency of the rubber and the temperature of the air inside/outside the tire along with the temperature of the asphalt.
Here's my non-contribution to the thread.....
It's interesting how car enthusiasts feel the need to compare themselves to one another. Whether or not 277 horsepower is a lot or not is a static fact, it has nothing to do with the acceleration speeds of my car. If a fat man tells another fat man he's fat, does the size of the 1st fat man make the 2nd fat man any skinnier? But regardless, I'm not going to be concerned with how fast it is or isn't, I know nothing about racing or building a race car. So I may be totally wrong in thinking it, it just still doesn't seem that fast to me. Not that it's relevant to anything, I'd probably pay money just to be able to look under his hood, it's still cool as a build. Just average for a power rating.
Old Aug 30, 2006
  #39
trurace's Avatar
trurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the rough
How is 277whp average for any civic? What do you consider alot of horsepower? You did say "I know nothing about racing or building a race car", so I assume you have no idea what you are talking about.
P.S. The 2nd fat man is skinnier
Old Aug 30, 2006
  #40
D5cIvIc's Avatar
You say you know nothing about racing or building a race car, but yet you say his 277 WHP in a CIVIC is not fast. You my friend have just owned yourself.
Just go out to your car, floor it and judge how fast your civic is. Then take how fast your car was at WOT and times it by like 3-4 times that speed if not more, then you have his car.
Old Aug 30, 2006
  #41
im thinking moire like 4 or 5, but okay... anyways, theres always going to be a hater, of a faster ciciv on this site. True, a 13 really all isnt that fast, but as compared to a stock 15.8 if you lucky, thats a considerable difference, and with slicks and the perfect tune i probably could even dip down in to the 12's. And last i checked that was fast enough to keep up with some of the big boys out there.
Old Aug 30, 2006
  #42
DeX's Avatar
DeX
Canadian, Eh!
I've figured it out that you're comparing it to a regular Civic and I'm comparing it to other attainable cars like the WRX. It makes sense to me now, so yes, it's fast in comparison to something as hellishly slow as a stock Civic.
Old Aug 30, 2006
  #43
D5cIvIc's Avatar
Even if you're comparing his car to a WRX. He can almost pretty much take out most of the WRX that are out there. A civic with a stock K20a2 can take out a stock WRX any day of hte week.
Old Aug 30, 2006
  #44
trurace's Avatar
WRX's are not even on the same level as this guys civic. I think by WRX you mean the STI, even if you are talking about the STI, he could still give the STI a good run (from a roll ).
Old Aug 30, 2006
  #45
D5cIvIc's Avatar
Well i know his civic can take out WRX. I'm aware of the speed of his car, its DEX that is still confused.
Old Aug 30, 2006
  #46
I could even go from a DIG, with the right tires lol. One word.. Turbo lag he he he.
Old Aug 30, 2006
  #47
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
My turbo with d17 with ~200whp is neck to neck with regular WRX, so Transformers car is like 911 compare to mine.
I totaly dont think that stock WRX is seriosly fast straight line car, it is heavy and 4wd takes extra power to turn wheels. It is good from dead stop, but advantage slowly dissapering with acceleration due to engine need to turn 4 wheels. Nonetheless WRX is a very good car and I like it.
Old Aug 30, 2006
  #48
Originally Posted by Sujak
Dex why the **** do you continue to dis believe him? What has he done on this site besides bring us good/real info? His attitude is not that of a liar.
Can't you just appreciate his thread for all the hard work he's put into his car?
hey dont worry about dex... when he can race me, and beat me i might actually care what he has to say. This is a forum and people are intitled ot share there opinions. And there only words on a page. After a while they can be forgoton. Its no big thing. But thanks for the back up!
Old Aug 30, 2006
  #49
DeX's Avatar
DeX
Canadian, Eh!
Holy smokes, why does everyone think I'm disbelieving him? We've come to the conclusion that...
1. his car is rediculously fast in comparison to what it started out as
2. he's done an awesome job with such a huge build to get it where it is
3. it's my opinion that 277 horsepower in a car of some sort is not a lot
4. I'm not basing 3 as relevence to what it started out as, just a general statement
5. I have a very very very nice stereo in my car compared to what it started out as originally. But is it very very awesome in general? No, it's okay.
At no point in time was I dissing Transformer, his car or his build. Why can't you accept I have a personal opinion and let it go? It's like I have to be impressed by it.
Old Aug 30, 2006
  #50
just one note here lol.. its Transformed!! BG.. Meaning Transformed BY GOD. Not a transformer like the cartoon lol.
Old Aug 31, 2006
  #51
D5cIvIc's Avatar
^haha autobots transform!
Old Aug 31, 2006
  #52
Civicman1988's Avatar
thats ncie glad to hear are civics can be something lol
Old Aug 31, 2006
  #53
I just realised it is "Tranformed" not a Transformer...lol
Old Aug 31, 2006
  #54
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
always wondered what TransformedBG meant...good to know others are reading bible..
Old Aug 31, 2006
  #55
trurace's Avatar
What do you think is alot of horsepower??
I still don't understand why you don't think 277 is not alot of horsepower. Could you give me some cars that you think have alot of horsepower? I don't want you to be impressed by his car I just want to know what you consider alot of horsepower
Everyone thinks you don't believe him because
I doubt you killed a Hemi in a civic, isn't that a V8? Or is it a straight 6? It's a 429 right?
BTW Optimus Prime
Old Aug 31, 2006
  #56
DeX's Avatar
DeX
Canadian, Eh!
Oh, right. I should have said that I changed my opinion after reading his build. The post about the Hemi was prior to knowing that.
The reason I don't think 277 is a lot is because many average cars come stock with that, domestics have been doing it for decades without a price tag that will rape your wallet. Now I'd cut my throat before I ever bought a domestic, but it's just way too common to now say this rating is impressive.
I would, however, say it's impressive in comparison to what he started with, which is where the confusion was coming from.
Old Aug 31, 2006
  #57
Civorama's Avatar
Civorama is an unknown quantity at this point
The hemis are a v6 i know this because my dad and i did our homework on them seeing as we just bought one today but not the hemi just the regular v6 pimp car
Old Aug 31, 2006
  #58
trurace's Avatar
Really???? I thought the Hemi in the 300c was a 5.7L V-8 .
Old Aug 31, 2006
  #59
Yeah its a v8 not a v6 apperently you didnt do you homework too well there Civorama...
http://www.automedia.com/2005/Chrysl...ts200409013c/1
Old Sep 7, 2006
  #60
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
Well look at what a 270whp N/A CIVIC K24 can do to an EVO. And you tell me 270whp isnt fast in comparison to WRX, STi, Hemi, etc...LOL DeX your an idiot.
http://video.google.com/videoplay?do...51377361927206
