nitrous malfunction.... must read!!!
Old Mar 16, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
to cut the story short, forget the scion, I made a full 90 degree turn with the nitrous on and luckily didnt damage anything. My low oil-pressure light came on shortly after that mistake and stalled for a second. I was just wondering what this could be, did I do any internal dmg?
mods please move to street forum if this is not the appropriate place to post this thread cause I was debating on posting this in the track/street forum...
Old Mar 16, 2005
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
First off are you retarded? Why would you be speeding at 100 in a 40?? What do you expect? Slow the FVCK down. And if a truck is chlling waiting to turn. Then slow down, and wait till he turns..Don't be doing stupid illegal turns and crap...
btw...your post made no sense....You made the left turn and then you beat a sion in neutral??? .....
Old Mar 16, 2005
im stock now! T.T
Old Mar 16, 2005
gsrchad's Avatar
gsrchad is an unknown quantity at this point
im jsut guessing that sinec your oil sits on the bottom and you turn hard enough, it might trick the opil pressure sensor into thinking there less oil cause of the sharp turn and making the oil slide to one side........
my motor does stupid things like, trying to get it to warm up to use vtec, sometimes it wont go off for like 10 minutes after i start her up...
i have to turn it off then back to get the vtec to work.. only happened a few times, 2 actually, but its stupid things like that, that i hate cause i cant figure them out...
Old Mar 16, 2005
im stock now! T.T
yeah, but the battery light came on too at the same time. It was very odd, something I never experienced before. Im going to change my oil before using it again. I been using synthetic for 7k miles and this is the outcome.
Old Mar 16, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Moved per request....
Old Mar 16, 2005
nindoo's Avatar
Why is my vagina bleeding?
if you feel your VTEC isn't engaging is it best not to rev the car high, just pull over turn it off and start her up again?
Old Mar 16, 2005
djmota's Avatar
Your car just did what it was supposed to. the oil sloshed away from the pick up tube (because of the turn) this caused a sudden drop in oil pressure, the ecu senses this, and stalls you motor.
Old Mar 16, 2005
im stock now! T.T
thanks!
Old Mar 16, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
I am sorry, but I am not getting where nitrous fits into the equation. 90 deg turn + nitrous=fvck up ??? The nitrous had nothing to do with it. Since you edited your post I am assuming that you were hitting the nitrous at high speeds made an avasive movment and the low oil pressure light fliped on. I would say that if you were going very, very fast and made a quick turn then it may do that from the amount of G forces. However unless you have made alot of steering modifications to your civic I don't see you making a turn that creates enough force to do so without compleatly understeering and just sliding sideways. I have no clue what this post is about LOL??????????
Old Mar 16, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
So the car cut off?
Old Mar 16, 2005
gsrchad's Avatar
i have a light beside my rpm gauge...
it didnt go off, and let off the throttle. and did it again... still nothing... so i drove around a little more and still nothing. stopped and turned it off... turned off my fuel pump and sat the car fora bout a minute. turned everything on and it was fine... did this to me 2 times... Fing stupid..... but it hasent done it for about a yr...
Old Mar 16, 2005
Boosting Daily
/\/\ VTEC solonoid messing up?
mjdiaz89
Jun 21, 2016 09:26 PM
alinaray
18
Aug 24, 2015 01:04 PM
JetsterDajet
Aug 15, 2015 08:07 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
robbie374
Jul 7, 2015 02:56 AM
