how to read a time slip?
Old Nov 17, 2004
Voiceofid's Avatar
End Bringer
i know what all the numbers on the time slips are, but how do i know what i need to improve in by the numbers?
here's my time slip
Old Nov 17, 2004
scatman's Avatar
Still in the game...
improving your r/t would help a lil, ive gotten .102, any time cut down will help
Old Nov 17, 2004
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
u can still improve your 60 ft time.
Old Nov 17, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
The biggest improvement you could make is cutting a better light. You should be in the .540 range consistently. That'll make you competitive without redlighting too often. Presuming your driving a civic, the 60s look consistent with the rest of the run. If your tires are spinning off the line, that'll cost you a tenth or two. However, the times are pretty good for a civic.
Old Nov 17, 2004
Voiceofid's Avatar
End Bringer
it's not, it's my turbo mr2 running 14psi and the time is very crappy for the car, and i am wondering why
Old Nov 17, 2004
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
How much HP are you putting out and how much does your car weigh?
Might be able to get a better idea of what you should be running.
What rpm are you launching? Are you bogging off the line? Are you shifting between gears as fast as possible?
Those numbers are just like a Spec-V with a good driver.
Old Nov 17, 2004
Rsxtc's Avatar
Rsxtc is an unknown quantity at this point
your reaction time has no effect on your 1/4 mile ET.
Old Nov 17, 2004
04civicvp's Avatar
04civicvp is an unknown quantity at this point
Exactly. Improving your reaction time will only help you in competition. As for your 1/4 mile time, work on your launch (60 ft) and maybe get a dyno of the car so you can see where you are making the most power and adjust your shift points to suit.
Old Nov 17, 2004
civic01vtec's Avatar
werd.................practice your launches and get your 60' times down.
Old Nov 19, 2004
SMX's Avatar
SMX
Let me preface this by saying I know squat about MR2s...
I'm guessing the MR2 weighs ~2400 with you in it. At your trap speed, you're making ~146 whp. That ought to be good enough for ~14.8 times. It looks like you're losing 0.4 secs. That seems like a lot to be lost in the first 100 ft, which suggests you're also losing time on your shifts. This is a long winded way of saying you need to practice your launch and shave a couple tenths off your 60 and improve your shifts to shave the rest. That combination should be enough to shave 0.4 secs.
Seems to me like you ought to be making more than 146 whp with 14 lbs of boost. A stock 2000 (non turbo???) I found on the net ran 15.2 @ 88. I'd recommend some dyno time if you haven't done it to tune your combo.
Old Nov 20, 2004
Voiceofid's Avatar
End Bringer
at stock boost, it supposely run the 14.8, which is estimated at 160rwhp at 20% transmission loss
i noticed when i launch, usually at 3k, the car bounces, my friend said my wheels are probably bent to hell. and i am also trying to determine is the car running in safe mode from the bad fuel l had in there... i guess i won't be able to tell till i get all that fixed, thanks for the help
i guess my driving skill is largely at blame, i've only drove a stick for about 4 months so far
Old Nov 20, 2004
7thGenLX's Avatar
Yea in my spec-v i ran a 15.205 @ 90.91 with a 2.291 60' all u have to do is improve ur reaction time and see if ur wheels are bent man if they are theres ur solution good luck
Old Nov 22, 2004
SMX's Avatar
SMX
Sounds like basic wheel hop. That's cured by working on your suspension so you get better weight transfer to the rear tires on launch. My tires hopped and burned through second gear on my first race running high 13s. It now runs into the 11s with no a wheel spin or hop thanks to slicks and suspension work.
Old Dec 11, 2004
00celicagts6spd's Avatar
kind of an old thread but what the hell. lol
1) run less tires pressure then ou do on the street. you should drop it by at least 10psi. in the rear only of course.
2) with that car you should have consistent 1.9's easily. that alone can shave off .3 seconds. also every .1 you save on the 60' takes about .15 off the 1/4 that should get you in the 14.6 range. might wanna try slippin the clutch at 5500 rpms. I heard that works pretty good in the mr2.
3) check out www.mr2oc.com you'll find a lot better info on your mr2 there.
Old Dec 11, 2004
allmotor's Avatar
nor cal 7thgens
yeah practice ur launch and if u can i would get some drag radials
werdnahall
May 17, 2015 11:37 AM
crowtoo
May 11, 2015 06:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
thesushiboy
Apr 12, 2015 07:40 PM
duyaknow
Nov 23, 2001 07:28 PM
