Do I suck at driving, or what?!
Old Oct 21, 2004
  #31
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
It's been proven long ago that there is next to no difference in speed between lx/ex. that 12 hp is a crock.
Old Oct 21, 2004
  #32
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
@ nopi race wars in maryland this past summer I ran a best of 14.9 @ 93 on 5psi, 2.5 sec 60s on stock tires @ 18 psi (lol), and stock clutch slippin like mad in 2nd gear...i can post slips if you like....
Brandon
Old Oct 21, 2004
  #33
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if I'm not mistaken, the final drive is different for ex's and lx's ...
ex's 3rd, 4th and 5th are shorter ... 3rd tops out at 87, 4th 110, 5th ?
lx's are a bit longer ... 3rd tops out at 91, 120? (limited to 115)
that's part of why it helps out in the 1/4 mile
drivetofast ran his car at the track a few months ago ... at 6 psi, achieved a best of 14.7 with a 2.4 60' time
Old Oct 22, 2004
  #34
JoeB18R's Avatar
New Member
From: San Diego, Ca, USA, Western Hemisphere, Earth, Sol System, Spiral arm of the Milky Way Galaxy
JoeB18R is an unknown quantity at this point
60' - 2.571
330' - 6.798
1/8 - 10.198
1000 - 13.113
1/4 - 15.588
MPH - 90.89
Good news and bad news.
To answer your question, no. You aren’t that bad a driver. That’s the good news. The bad news is that your car is pretty slow for having aftermarket boost. Even if you were able to solve your traction problems and cut low 2 second 60' times, I cant see your overall ETs and trap speeds improving that much. Given that you are trapping at 90MPH, id say you will more then likely be puling down mid 90s with a proper start. What does this mean? That, in reality, even with slicks and 8PSI of boost, you are only going to be ripping off very high 14 second runs. Id be surprised if you ran faster then a 14.8@~95 at the most and thats with a good tail wind behind you, and perfect track coditions.
Unless you plan on making more power, you aren’t going to be beating too many things on the street or at the track. As of right now, it seems like wasted money. Hell, I managed to cut a 15.2@92 when my Si was bone stock (to give some perspective) I hope you can find more power in dyno tuning, because unless built, I don’t think your engine is going to be taking too much more boost. Not if it’s a daily driver.
As for the motor mounts, they will hewith wheel hop at launch (or between shifts if you make enough power), I would go with the Energy Suspension versions. The Prothanes are too hard and promote too much vibration transfer into the chasis and steering column.
Old Oct 22, 2004
  #35
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
Originally Posted by JoeB18R
60' - 2.571
330' - 6.798
1/8 - 10.198
1000 - 13.113
1/4 - 15.588
MPH - 90.89
from a dig, I raced a 99 SI with I/E and he beat me out the hole but I caught him and put a couple cars on him and was STILL PULLING by the time I shut it down...oh btw, I only hit 5psi on him and my BOV was hanging out....guess he cant drive either huh....damn I guess u're the only one that can drive these days
oh yeah search the site, there are guys on here that have run mid 13's and me, I beat a mid 14 sec SRT4 running that was running 7psi (I was running 8psi)...once again he beat me out the hole b/c I was spinning and caught him...he was surprised...btw, I had a passenger and was on my stock tires at the time...so dont come on here hatin bruh 4real b/c u willl get flamed real quick so I suggest u search the FI section before your next post and suit up b/c the fire is burning lol
oh yeah, a guy in my club with the TSI kit on his D17 ran a best of 13.6....damn thats pretty slow for having aftermarket boost...WHO KNEW!!
Old Oct 22, 2004
  #36
JoeB18R's Avatar
New Member
Those are some interesting stories.
I would hope ANY generation of boosted civic would be able to beat an (essentially) stock 99-00 or 02+ Si.
It’s nice that you beat an SRT-4. Especially since the driver managed to pull a mid 14 second pass with a car that’s capable of high 13s, stock.
I am also THRILLED to hear that some guy who isnt you, me, or the person that started this thread can run mid 13s. You know, I have a friend who runs mid-high 10 second passes in the ¼ mile. Does that make his kack bigger then yours or mine? Here is a better question. DOES IT MATTER?
This would all add to be a really great reply to my post, except for this one fact...
IT MEANS JACK SQUAT.
None of that BS you just mentioned has ANYTHING to do with this specific situation, the original posters car, what he ran, what he has done to it, or what I said in response to this thread.
What was your point again?
Old Oct 22, 2004
  #37
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Exclamation
Originally Posted by opto_isolator
Just got back from the track tonight - My times were not impressive by any means.....My car, as most of you are aware of, is boosted. First run I did was 15.8 at 89 MPH. This was around 4-5 PSI of boost. Second run, dumped the clutch, 16.6 at 91 MPH I believe. This was at about 8 PSI of boost. Third run, same boost, around 15.5 @ 92 MPH.
I was slipping up to third - but damn, 15.5?? I was expecting to break 14s!!!
A lot of folks were very impressed with the install of the turbo, non-the-less - guess no one here in Orlando has seen a 2001+ series civic that's been turboed!
What's your turbo setup? This sounds like runs from a T25. If your running a T3 on 8lbs of boost and doin mid 15's i'd say you need hella amounts of practice!
Old Oct 22, 2004
  #38
JoeB18R's Avatar
New Member
If you look at his trap speed, you will see that it’s not the driving that is his problem. It is power production. With low-mid 90MPH trap speeds, he isn’t going to be hitting anything better then low 15s, or VERY high 14s.
But I guess pointing that fact out is "hating", so here you go guy...
WAY TO GO! OMG a TURBO CIVIC! MAN that’s AWESOME! Keep up the good work!!!! *jacks off to pics of your engine bay* UNF!
Xuhme
21
Aug 7, 2023 03:40 PM
smmahan
Apr 15, 2015 08:17 PM
