Do I suck at driving, or what?!
Old Oct 13, 2004
opto_isolator's Avatar
Just got back from the track tonight - My times were not impressive by any means.....My car, as most of you are aware of, is boosted. First run I did was 15.8 at 89 MPH. This was around 4-5 PSI of boost. Second run, dumped the clutch, 16.6 at 91 MPH I believe. This was at about 8 PSI of boost. Third run, same boost, around 15.5 @ 92 MPH.
I was slipping up to third - but damn, 15.5?? I was expecting to break 14s!!!
A lot of folks were very impressed with the install of the turbo, non-the-less - guess no one here in Orlando has seen a 2001+ series civic that's been turboed!
Old Oct 13, 2004
doubledeuce2k2's Avatar
you got slips?
Old Oct 14, 2004
jonnyg's Avatar
E36 M3 Driver.
jonnyg is an unknown quantity at this point
what are your 60' times?
Old Oct 14, 2004
gh0st's Avatar
TAQUITOS!!!!
practice makes improvement
Old Oct 14, 2004
Well - I don't think the fact that I had about 32 PSI of air in my tires helped either! :doh:
Anyhow, my times are as follows:
60' - 2.571
330' - 6.798
1/8 - 10.198
1000 - 13.113
1/4 - 15.588
MPH - 90.89
Guess I need practice too!
Old Oct 14, 2004
someguy's Avatar
someguy is an unknown quantity at this point
yeah your 60's could improve...but i dont know what would be decent for our cars. (no lsd=no traction)
Old Oct 14, 2004
civic01vtec's Avatar
hey Travis.........your 60' times blow
j/p........ was that ur first time ?? You won't hit 14's ur first time......... keep practicing bro.
Old Oct 14, 2004
Nick's Avatar
Formerly 2blu
what did your car run before u got boosted?
Old Oct 14, 2004
djmota's Avatar
rev it up so when you launch the turbo is spooled. Adjust your gas pedal to how much traction you have. If your spinning let off just a bit until you hook then drop the pedal once more. Sounds easy but as you found out it takes practice.
Old Oct 14, 2004
jonnyg's Avatar
E36 M3 Driver.
try to modulate/slip the clutch more to control your wheel spin
Old Oct 14, 2004
Yeah, I know
First time was 15.8, than 16.6 (when I dumped the clutch by mistake), than 15.5.....
The car ran 17.7 stock.....
Old Oct 14, 2004
tripledoublegs's Avatar
Euro-Spec
60' - 2.571
wow man, your 60's suck. Practice a bit before going to the track again
Are you on 17's?? Get some lightweight 15's or even 16's, drop the tire pressure to low 20's on the front and you're good to go.
Old Oct 14, 2004
Originally Posted by tripledoublegs
60' - 2.571
Heh - yeah, I'm on 17s....and they are heavier than stock I think!!
Thanks for the advice guys....Any bit helps!
Old Oct 14, 2004
civicvtec1ps's Avatar
Search and Learn
Yea, You can get 2.2's on stock tires.
Easy 14's.
Keep Practicing.
Old Oct 14, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
eh? what kind of tires?
Old Oct 14, 2004
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Shouldn;t your trap speed be like closer to 100 at 8-9 PSI regardless of how much traction you get off the line? First time i went to the track i spun the tires hard and shifted to 2nd and my rpms sunk to lik 2500. I ran like a 18.7 but still was goin 82 mph. I was stock BTW.
Old Oct 14, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
Stock tires for 04 EX's are them Potenza's. They got some decent tractionage. Did you say you were slippin in and through 3rd gear? You may need a more heavy duty clutch on yer tranny there man. If you haven't gotten one already, I would suggest that clutch pack from ACT.
Old Oct 14, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
If you have the money, a set of drag radials will help.
Old Oct 14, 2004
Already changed the clutch to ACT xtreme with streetlite flywheel....I meant that the tires were slipping, not the clutch.
As far as the car goes - I blew at least 1 motor mount either last night, or through the course of driving the car hard. I discovered that **** tonight. This things becomming a fast money pit once the turbo was installed....
Time for some polyurethane motor mounts.
As far as the tires, I have Yokohama AVS ES 100's - good tires, just didn't drain pressure from them....
Old Oct 14, 2004
nindoo's Avatar
Why is my vagina bleeding?
What is the best time our cars can do stock? I mean if you put a pro at the wheel, can you break 16's?
Old Oct 14, 2004
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
I ran 16.9 stock in my 04 VP/DX with a 2.399 60ft. So maybe 16.5 for an lx/dx. 15.7-15.9 for EX.
Gonna see if I can hit 15's sat. night with just bolt ons, if my motor mounts come tomorrow.
Old Oct 14, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
you should not need to drain the pressure from them to run good times ... when I was turbo'ed, my tire pressure was around 38 psi on my goodyear's and I still managed to take out countless wrx's and such
Old Oct 14, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
first suggestion dyno the car and see if its putting out the numbers needed to get those times. second practice your driving and do it at the track so you know what technigues are helping you and which ones are hurting you. Also a 17.7 stock is good if its auto if its a stick then i dont know what to tell you because I ran a 16.3 stock on a lx sedan 5 spd and im hopping to get a 15.9 with my mods next time out.
Old Oct 14, 2004
jonnyg's Avatar
E36 M3 Driver.
those times between the lx and ex are way too big. A ~15hp advantage towards the ex, doesnt produce a .6-.8 sec. difference btween the 2.
Old Oct 14, 2004
Farage's Avatar
I like you! do you like me?
whats your reason for getting rid of the turbo kit?
Old Oct 14, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
let's see ...
-smoking from day 1 (stopped after replacing the turbo)
-SHITTY install job (got SF to thank for that), caused me MANY hours of re-arranging intercooler pipes
-blew 2 headgaskets (after I sold the kit, I found out was due to:
-cracked fuel pump (ran hella lean, blew head gasket)
-not satisfied with welding job
-got a stud broken off from one of the exhaust bolts (from a shitty installation job, thanks to SF)
yeah, I think that's about it
but it made tons of ****in power ...
Old Oct 14, 2004
Farage's Avatar
ahhh so SF are good guys i see
Old Oct 14, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yeah. real great. I was only at 7 psi too
Old Oct 15, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
60' - 2.571
330' - 6.798
1/8 - 10.198
1000 - 13.113
1/4 - 15.588
MPH - 90.89
I need practice too...I'm gonna post my timeslips when I get back home friday night...if not friday night, saturday night...yeah practice man
just know on my first run, I ran 16.2@94.XXmph with a 2.9 60'
on my 18's...car wasnt gutted with random shitt in trunk with a busted (didnt know at the time) radiator...the car ran hot the entire time at the track...I will get back to you guys when I get home to my slips...I'm out of town right now
Old Oct 21, 2004
nindoo's Avatar
Maybe that combined with the shorter gearing. But then again the EX is heavier
