1/4 Times...
Old Jun 26, 2004
civicvtec1ps's Avatar
Search and Learn
1/4 Times...
2003 Si.
Mods
AEM CAI
Hondata Reflash
Greddy sp2
J's engine damper
The best run.
R/T .300
60' 2.300
330 6.503
1/8 9.872
mph 73.04
1000 12.773
1/4 15.175
Mph 93.01
R/T .250
60' 2.331
330 6.402
1/8 9.806
mph 72.45
1000 12.740
1/4 15.222
Mph 91.51
R/T .091
60' 2.307
330 6.450
1/8 9.873
mph 72.24
1000 12.808
1/4 15.291
Mph 91.69
R/T .652
60' 2.368
330 6.462
1/8 9.870
mph 72.45
1000 12.805
1/4 15.292
Mph 91.45
I need to work on launch.
If i could do 2.2's and less wheelhop.
I should be able to do 14's.
Also planning to take out rear seats( 40 lbs) next time i go to the track.
Old Jun 26, 2004
Mr.Modify's Avatar
i can beat chu nice times
Old Jun 26, 2004
Search and Learn
Thanks.
I am hoping to get 14's soon...
Old Jun 26, 2004
MadWheel's Avatar
Premium Boosted Member
You can def do it man. I used to have the same times.... Get a slightly better launch, find the right shift points, and take some weight off (like you said) and you should be all set.
What rpms are you launching at? You dumping the clutch or feathering it?
Old Jun 26, 2004
Search and Learn
Feathering at around 4200.
Still some wheelhops even with damper but es motormounts will be here next week so.
I will get to 14s in 2 weeks.
Old Jun 26, 2004
HoldDaMayo's Avatar
HoldDaMayo is an unknown quantity at this point
impressive
Old Jun 26, 2004
Search and Learn
Also had 16" wheels.
Going to put stock wheels back on next time i go the track lol.
Old Jun 26, 2004
icebergslim's Avatar
BOOSTED HYBRID
icebergslim is an unknown quantity at this point
What psi are you running in your tires. Try lowering the front set and fill up the rear. I run 20psi in my front set of tires and around 50 psi in the rear. Also if you have adjustable suspension set it soft up front and stiff on your rear tires.
Old Jun 26, 2004
Search and Learn
That's the another problem i have.
My suspension setup sucks.
Using coupe Tein s tech springs on stock shocks.
I ran with 27psi on front tires, 33psi on rear.
I will lower pressure on rear and raise up rear next time i go there.
More tips are helpful.
This was second time at drag strip and i was able to get better reaction time than before.
I am learning..
Old Jun 28, 2004
00celicagts6spd's Avatar
get your launch down to 2.2's where it should be and you'll be close to 14.8's
I dunno too much about the SI. do you have the 5500 limiter in nuetral like the type S?
Old Jul 14, 2004
NorthernNinja's Avatar
NorthernNinja is an unknown quantity at this point
I like that 93mph trap speed. With the advice you got here and those motor moutns 14s are in your future!
Old Jul 15, 2004
motor mouns arent a magical cure for bad launches lol alot of times it makes you worse until you figure out a better way to launch.
Sep 27, 2015 11:33 AM
david34
Sep 23, 2015 11:13 PM
bsmiley
31
Sep 1, 2015 06:11 PM
honda.lioness
Aug 6, 2015 11:58 AM
TheRubixHorse
Jul 29, 2015 05:22 AM
