Went to 1/4 Mile Times Inside
Old Oct 22, 2003
LazyDog01's Avatar
Raceway Park Track Tech.
Talking Went to 1/4 Mile Times Inside
Nice night out. 49 degrees outside.
My first run:
Rt 1.037
60 2.650
330 7.181
1/8 10.888
MPH 65.99
1000 14.098
1/4 16.798
MPH 83.73
My Second run
Rt .772
60 2.504
330 6.972
1/8 10.670
MPH 66.14
1000 13.867
1/4 16.559
MPH 83.91
My third run
Rt .854
60 2.379
330 6.808
1/8 10.475
MPH 66.72
1000 13.653
1/4 16.336
MPH 84.08
My fourth run
Rt 1.007
60 2.573
330 6.925
1/8 10.579
MPH 66.89
1000 13.756
1/4 16.438
MPH 84.17
My Fifth run LAST
Rt .893
60 2.464
330 6.925
1/8 10.631
MPH 65.99
1000 13.838
1/4 16.541
MPH 83.56
My 3rd run was the best. my car in Stock. 2003 Civic EX stick. all in all it was great night for me these are my best times in the civic.
Old Oct 22, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
16.3 ... that's not bad ... about what the magazine times posted hehe
looks like u need to work on those reaction times ;P
Old Oct 22, 2003
00celicagts6spd's Avatar
hey bro, If you get your 60 ' times down you could hit high 15's!!! No offense but those launches are not so good. ask some of the guys here some tips!!
Old Oct 22, 2003
CarbonFly's Avatar
Reaction Times has NOTHING to do with ET!!!
Old Oct 22, 2003
LazyDog01's Avatar
i have been either i drop at 3000 and spin the tires or i just go from 1000. but all in all it was a great night.
Old Oct 22, 2003
nme3's Avatar
JDM wannabe
you still running on the stock firestones right? what do you find better launching at 3000 or 1000
Old Oct 22, 2003
LazyDog01's Avatar
i got stock firestone. and lanching at 1000 tires don't spin.
Old Oct 22, 2003
EviLMyStS's Avatar
All show!!!
Nice times for stock ^^
Old Oct 23, 2003
papi2001civic's Avatar
papi2001civic is an unknown quantity at this point
i went with him too and got a few decent runs in too... my car is a 2001 DX and basically stock exept for my ricey muffler and a revo ss ....
run#1
r/t -.694
60'- 2.712
330- 7.375
1/8- 11.2
mph- 64.16
1000'- 14.49
1/4 mile- 17.312
mph- 79.80
run#2
r/t- .302
60'- 2.441
330- 7.029
1/8-10.88
mph-63.63
1000'-14.201
1/4- 16.994
mph- 80.78
run#3
r/t- .226
60'- 2.469
330'- 7.071
1/8- 10.901
mph-63.85
1000'- 14.205
1/4- 16.990
mph- 80.99
run#4
r/t- .260
60'-2.563
330'- 7.247
1/8- 11.12
mph- 63.03
1000'- 14.470
1/4- 17.280
mph- 80.29
run#5
r/t- .294
60'- 2.443
330'-6.972
1/8- 10.78
mph-64.20
1000'- 14.068
1/4- 16.842
mph- 81.25
it was a great night and lazy dog is a really cool guy.... cant wait to do it again
Old Oct 23, 2003
J30A1's Avatar
J30A1 is an unknown quantity at this point
nice times!
Old Oct 23, 2003
LazyDog01's Avatar
thnx yea we had great night .. going again this wednesday
Old Oct 23, 2003
PAPI2001 please don't take offense to this cause I'm willin to help you but .....
I'm wondering if this was your first time out to a track?
Some advice:
lower your tire pressure in the front to 18 psi raise the back to about 40 psi
If you are on the .500 is perfect tree then STOP redlighting wait til you see the last yellow light turn on then go this will give you very good R/t's and you shouldnt redlight. looks like you are going on the first light maybe the 2nd.
Your launches look like 70% of your problem. 2.7 60' is just a big no -no .
Also I noticed your other 17 second run. It looks like you might be shifting at radom rpms. do you not have a tach? if not get one! Seems to me like your shifts are irratic and a lil slow.
but keep practicing and you'll get there! you should be able to hit mid 16's with your current setup!! Good Luck
Old Oct 23, 2003
CarbonFly's Avatar
Some tracks show your R/T starting from .000 not .500. I know both of my tracks down here do that.
Old Oct 23, 2003
i'm pretty sure its a .000 because i didnt red light once.....and i am shifting at random rpm's because i wanna see where it works better for me .... and yes i do have a tach.... but my launches are weak i know that.... I'm a lil worried about going that low on tire pressure... do u think it might mess up my rims or its ok?
Old Oct 23, 2003
LazyDog01's Avatar
i did stock tire pressure with mine .. and remeber he is a DX with those times. and this was his second time going to the track.
Old Oct 23, 2003
well at least you know you were shifting at different rpms!! From my experience the best place to shift is right before fuel cutoff on almost any car. that way you land in the peak powerband!!!
If you worry bout beating the guy next to you then your R/T's are kinda high. You should launch at the third yellow light!
Not bad for 2nd time out shows you're actually trying to get faster!
with the tire pressure you'll be fine! The tires will heat up and expand giving you more traction, less spin. You raise the rear tire pressure to reduce rolling resistance.
I'm wondering if you are giving it too much gas on the launch? when you let off the clutch you should NOT go full throttle. you only go full throttle when you feel the car start to hook!
Also try taking vids of your run from inside the car it'll help you to see what you may be doing wrong!! Good Luck!
Old Oct 23, 2003
koool.....thanx...i usually launch around 3000 i think this might be the problem...because i'm getting some wheel spin
Old Oct 23, 2003
CarbonFly's Avatar
i launch at 3K also.......whenever launching at anything less my car bogs. So basically get yourself some drag slicks.
Old Oct 23, 2003
you need to controll how har dyou step on the gas. you should get 2.2's without drag radials or slicks. until then you arent driving right! so I suggest workin in it and then upgrading to drag tires!
Old Oct 23, 2003
that way instead of trying to get 2.2s you will be look at hittin 2.1's & 2.0's
Old Oct 24, 2003
kool
i'll try working on it next week
Old Oct 24, 2003
LazyDog01's Avatar
u going again wednesday bro ??
Old Oct 25, 2003
i hope so ..... but i might have to go put my friends stereo system in his car so if i have time definitly
Old Oct 25, 2003
LazyDog01's Avatar
if u go tell me ttyl peace
Old Oct 26, 2003
Logan3024's Avatar
Are you serious, drag tires on a 17 second vehicle? to save a whole .2 off his time.
Old Oct 27, 2003
WITHOUT !!! I said without dr's!! But hey if he wants to get his times down every .1 counts!!
Old Oct 27, 2003
Logan3024's Avatar
NO YOU SAID..............
Old Oct 27, 2003
well who are we to say he can't strive to get the best times possible for his car?? thats just retarded. I mean I dont come here and say why even post in a racing forum when you are WAY to slow to race.
Old Oct 27, 2003
LazyDog01's Avatar
they car is not slow it the driver.....
mattdoc
Mar 14, 2017 12:10 PM
Bigdaddy198
Apr 30, 2015 08:36 PM
carid
Apr 30, 2015 07:00 AM
supercivic01
South
Nov 30, 2001 11:27 AM
HitlistCivic01
Oct 27, 2001 07:47 PM
