unorthodox crank pully
Old Oct 14, 2002
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
i am puttin on my crank pully on right now we will see what that does hopefully it will rev faster and i should get about 8-10 hp out of it. 3 hp per pound u loose off ur pullys
Old Oct 14, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
dude, you arent going to get 8-10 ponies from pullies. you might get 2 if you're lucky. but every bit helps!!!!!!
Old Oct 14, 2002
the more mods done to ur car the more u get out of these things and u have kno widea what i dot done . think befor u speak
Old Oct 14, 2002
nochopstix's Avatar
if you have a 2k1 civic i can guarantee you wont get that much hp unless you have a turbo or something. and so far on this site you havent shown any pics of your car and the mods you claim to have...............dumbass
Old Oct 15, 2002
BIG's Avatar
BIG
If nochopstix is a pro when it comes to performanc parts, he would know that pullies increase hp to the wheels by about 10%, so do the math bro
Old Oct 15, 2002
mohawkboom's Avatar
Ignorance runs rampant yet again. You'll free up 2-4 horsies only. The weight of the pulleys has nothing to do with the power gains. The Pulleys for the PS pump, and Alternator are larger with the pulley kit. This makes them easier to turn...it's a matter of simple leverage. The crank pulley is small. Thus making the belt turn slower....
The PS Pump will use up to 7hp under extreme pressure. The alternator can draw up to 4. Your not eliminating these drains..you lessening them by about 40%... your PS and Alt..generally only take up 2-3 HP under normal loads...So under normal conditions..you free up 1 horsie.... If you have a system in your car and your cranking it while making a sharp turn at high speed.then it will be harder to turn the car..and you'll free up the 4 horsies....
Get educated....you were thinking about the flywheel with your wieght comment...
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
68camerors
Sep 24, 2015 06:18 PM
Skunkone
Sep 24, 2015 04:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
