EJ1_MK Build
Rep Power: 0 EJ1_MK Build
So here is what I started with:
I have already added the steering wheel and the GPS but other than that she cam the way she looks. I will post more as I get pieces in the next several up coming weeks.
These are the wheels that will be going on the car as soon as I have get new tires and have them powder-coated black
This is of last 2 weeks of working on it had a ton of stuff to put on:
Well the rear is all done just waiting on a pin from Honda to show up tomorrow for the brake cable and it will be finished. Here are todays pictures:
And yes there is a screw driver in the picture it is where the pin needs to go. [hr]Well the control arms and spindle didn't get done today so I was at a stand still. Pretty bummed out right now hopefully he can get the bushing and the new wheel bearings in by mid day so that I can get the car on the alignment rack before 3 tomorrow. Will post more pictures as soon as more parts get put on.
And as of Today:
Well so I got the car on the ground to adjust the suspension, and get the ride height set up all around. Got it close but have to wait till the alignment is done until I can finish.
Still need to finish the brakes, the front pads where wrong of course, just another snag but its ok, gives me time to put my new master cylinder and prop valve if I can track one down.
I will list my mod list as soon as I write it all done and what my plans are for the car.
And as of Today:
Live for the Twisties
Rep Power: 261 Re: EJ1_MK Build
Wow, that's clean as ****.
Good move with the heat wrap on your intake, most people refuse to do that because they don't like the look, but it works great.
Rep Power: 0 Re: EJ1_MK Build
Thanks I hope to have it back on the streets soon and then get some professional photos done. And I most people don't understand the painting or wrapping the intake will cool the air going through it. Warm air in an engine is not good for performance.
Here is my mod list and what I want to do to the car over the next year or so.
Current Mod list:
Engine:
D16Z6
Header
Intake
Solid Mounts
Fuel pressure regulator
No A/C
No Power steering
2.5" exhaust no cat
Interior:
Sparco Steering wheel
Skunk2 shift **** off my EJ8
PasswordJDM Carbon Fiber Airbag Tray
All srs or airbag wiring removed including airbags
All sound debiting removed
Wink 5 panel mirror
C-Piller Bar
Exterior:
PasswordJDM Tow Hooks Black
OEM Honda antena Block off Plate
OEM Honda front license plate fills factory color
Rain Visors
Depo JDM Amber Corners
Brakes:
PasswordJDM Drilled and Slotted rotors front and rear
Hawk HP Plus brake pads all around
Goodridge Stainless Steel Brake lines
Rear disk conversion with new calipers and brackets
4040 Prop valve
Suspension:
Skunk2 Pro-C Coil-overs
Skunk2 Pro Front Camber Kit
Skunk2 Pro Rear Camber Kit
Skunk2 Rear Lower Control Arms Black
ASR Subframe Brace Black with 24mm Sway Bar
PasswordJDM 3 Point Strut Bar Front
PasswordJDM 2 Point Strut Bar Rear
PasswordJDM Trunk Bar
Hardrace Rear Trailing Arm Bushings
Hardrace Rear Toe Arms
Hardrace Compliance Bushings
Hardrace Extend Ball Joints or Center Roll Adjusters
Hardrace Outer Tie Rod Ends
Energy Suspension Front Lower Control Arm Bushings
Energy Suspension Front Sway Bar Bushings 21mm
Energy Suspension Front Sway Bar End Links
Energy Suspension Steering Rack Bushings
ARP Extended Wheel Studs
Buddy Club Racing Lug nuts Open
Wheels:
Winter 99 Miata wheels with Blizaks
Summer Konig Helium 15x6.6 with Yokohama S.Drive 205/50R15
Future Plans:
Engine:
K24 with 08 or newer SI Trans
More details to come as I Plan for this.
P.S. Motor is already sitting on an engine stand in my garage.
Interior:
Status Racing Seats Black Carbon Fiber
PCI Seat Rails
Status Racing 6 Point Harness Black
Nardi Steering Wheel
Works Bell Quick Release
Roll Cage
Exterior:
Plan on Re-painting entire car back to same color Paradise Blue Green
VIS OEM Carbon Fiber Hood
New Front and Rear Bumpers, Back is cracked and front had fog lights in the black grill section
PasswordJDM Carbon Fiber Spoon Replica Mirrors
JDM OEM Thin side moldings
Front Lip, But have yet to decide wither to stay with SIR or factory, or go Carbon Fiber Spoon or other.
Might Get JDM fenders with side markers, also have not decided on that yet.
Brakes:
WilWood 6 Pistion front brake kit to fit behind 15" wheels
Suspension:
K-tuned Traction Bar
Possibly upping the spring rates on the Coil overs
Fender Braces 3 Point
Spoon Rigid Collar Kit
There is others I will have to look at my list at home
Wheels:
Buddy Club QF 15x7
Work Emotions CR-KAI 15x7
Enkei Black RFP1 15x7 -- Track wheels tires
Various sets of tires for different courses/ Tracks.
Current Mod list:
Engine:
D16Z6
Header
Intake
Solid Mounts
No A/C
No Power steering
2.5" exhaust no cat
Interior:
Wink 5 panel mirror
C-Piller Bar
Exterior:
Rain Visors
Brakes:
4040 Prop valve
Suspension:
Wheels:
Future Plans:
Engine:
Interior:
PCI Seat Rails
Roll Cage
Exterior:
Brakes:
Suspension:
Wheels:
Buddy Club QF 15x7
Good move on the 24mm ASR rear sway, nothing improves handling on a Honda better than upgrading the rear sway.
Which k24 do you have?
I have a k20 currently, but I'm debating selling it and buying a k24a2 or building a k20/24. Gotta love the cost of modding/building k-series engines compared to b, d and h..
It is a k24a3 i believe I got it pulled apart and been sitting on the stand since. Been looking all the parts im going to need to put in the car and that is the part that is killer, to make power your right cost to build it is way cheaper than all other honda motors.
Dave Brabant
20
10-06-2015 12:44 AM
Touge
09-22-2015 11:55 PM
Touge
Ottawa
09-22-2015 11:52 PM
Touge
09-22-2015 11:52 PM
Touge
09-18-2015 12:13 AM
