B18C Winter upgrade / fixing time. /hype
this is whats currently in my car and whats going into it.
Current Mods:
B18C (JDM Type-R) Block
GSR Tranny
B16 Head
Skunk2 springs and retainers
ARP Headstuds
ProComp Pistons
Forged crank
Forged Rods
Cylinders mildly Bored out
Stage 4 Clutch
Golden Eagle Vacuum Block
Walboro 255 Fuel Pump
1000CC injectors
AEM fuel Rail
Hondata S200
Garret .70 A/R Cold side, Turbonetics Hot side.
Boost set to 17PSI currently
OBXRacing 44mm Wastegate
OEM Bosch spark plug wires
NGK Coppers
custom oil pan (holds 5.5quarts)
3"exhaust turbo back
Suspension:
Kyb struts and lowering springs (kinda low budget but it came with the hatch)
Camber kit
Misc parts and weight reduction:
The spare is still in it (you never know)
Rear Seats from a GSR (black or gray or whatever lol
Driver seat from an S2000 (Black or gray or whatever it is)
Stock cloth passenger seat (looking for a matching passenger seat)
Complete Powersteering delete
Complete A/C delete
no washer bottle (who uses that anyway)
Whats i am planning to put into it:
Upgrade from S200 to S300
DSS Stage 3.9 axels
Strengthen the tranny
upgrade to a Tial wastegate
Replace entire wire harness
Replace every ground and install an Apexi Grounding Kit.
I just got the ARP Headstuds in along with a new head gasket, timing belt, tensioner, oil pan, and oil pick up.
I hope to be able to have this all done by the time spring gets here. Then it will get Tuned and dyno'd.
Anyone have info / suggestions on what i should do to strengthen the tranny?
Let me know what you all think.
thanks in advance.
Current Mods:
GSR Tranny
B16 Head
ARP Headstuds
ProComp Pistons
Forged crank
Forged Rods
Stage 4 Clutch
1000CC injectors
AEM fuel Rail
Hondata S200
NGK Coppers
Suspension:
Camber kit
Complete A/C delete
DSS Stage 3.9 axels
thanks in advance.
Re: B18C Winter upgrade / fixing time. /hype
Now as far as the head goes...
its a B16 head and whoever put it together torqued the cam caps down WAY too tight... so the cams have some grooves...
Id like to get a new head (or damn near close to new). But ive seen / heard that going with a GSR or Type-R head isnt exactly the best way to go. people have said that B16 is the way to go and just get head work done.
if i get a new head im gonna do mostly EVERYTHING there is to do to it before it goes in my car. (port and polish, valve job, etc..)
what would you recommend?
stick with b16 head and get port and polish, 5 angle valve job, cam, springs and retainers, adjustable cam gear (aem 5 bolt preferably), etc. but be careful,port and polish is easy to mess up and different for na vs turbo. for turbo, you want both intake and exhaust sides done, since its best to have the most airflow possible. do not mill the head to raise compression (unless its not perfectly straight and needs a tiny bit shaved down), otherwise you will blow head gaskets. you could even see if they make oversize race valves for that head and stick those in. be sure once everything is assembled and the valves are adjusted properly that you prep it with assembly lube and everything. no need to have a dry start and take years of life off the parts.
depends what you want the car to do i guess. for road racing, you can get some pretty high quality pieces. just stick with name brands and dont lower the car too much.
Ive posted pics of the car on here before but that was a few months ago... so here ya go!!
(i know the date is wrong, and i need to get new ones now that the engine bay is a bit cleaner.)
haha, nope never driven in Connecticut with this car.
i wonder if santa is gonna bring me my new axels!! lol
OH BY THE WAY (ill start a new thread for this) id like to start a list of some people that have some cars that they would like to show off at some car shows. In my town there is a HUGE car show the first tuesday of the month, every month, throughout spring and summer. i would like to get a few people to come down. and show off their hard work.
there are a handful of very nice boosted / all motor civics, 2 Supras, 2 Evo's, a twin turbo 1000HP Viper, twin turbo GT500 stang, the list goes on and on and on. they usually have burnout contests and there are over 30 trophies for different types of cars and work done and what not.
i will have more info on these car shows as we get closer to spring.
UPDATE!!
I am replacing the B16A head that is on the car now with a fully built type-R head.
It is a Type R DOHC VTEC head orignally. It has been ported by Mike Belben, full port job for a Turbo Application. It comes with Supertech Dual Valve Springs and Titanium Retainers, stock size Supertech Valves (intake and exhaust) with a special Belben valve job that sinks the valves into the head further up and essentially makes them act like over sized valves without the worry of valve or piston clearancing issues.
so after that is all said and done i will be doing the following.
-New clutch
-new axels
-upgrade to hondata S300
she getting closer to being dyno'd and brought to the track
-New clutch
-new axels
mattdoc
Mar 14, 2017 12:10 PM
juror
Jun 9, 2015 02:15 PM
intensity
May 12, 2015 10:43 PM
tylerginevan
Apr 27, 2015 12:29 PM
