hid installation ?
hid installation ?
hey guys i installed my hid today. and for some reason i can see my high beam signal ( the blue thing ) its dimmed its not fully on. any clue to why?
Re: hid installation ?
the regular h4 bulb is hi and low beam on an 02. So with a single xenon kit hi beams are eliminated. Might want to check your wiring sounds like you could have them backwards and dont forget to buy/make a wire harness
my hid kit came with everything i needed. all the harnest and stuff. i found something searching with the diodes i can get my hi and low beam to be on the same time. iono if it applies to this situation tho
basically with the H4 system, only EITHER the low or high beam will be on.
however, if u use that diode, you can do it.
again, search and look for my thread. i did whole explanation on it.
since im such a nice *** hole......here it is.
https://www.civicforums.com/forums/1...e-lowbeam.html
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
