Front tow hook?
Old Mar 21, 2008
1sykcivic's Avatar
RHCP0801 is my hero
1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute
Front tow hook?
Any one have a front tow hook installed?
I got a benen one and I dont think I can mount it anywhere safe. Any suggestions?
Old Mar 21, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Re: Front tow hook?
I'm not sure, but I'm thinking you would have to bolt it to the front steel bumper re-enforcement bar. Which would probably require cutting a hole in the bumper one way or another. I've seen this one S15 that had the tow hook sticking straight up out of the hood like off on the side where the strut towers are. No idea other then those. You should just duct tape it to the front grille.......heh jk.
Old Mar 21, 2008
sl33pyriceboi's Avatar
Re: Front tow hook?
our civics arent made for it.....either are most cars on the road...
the reason for a front tow hook is for towtrucks to safely tow ur car off a racetrack if ever needed...
if u put it on, its just gonna be for looks...not actual practicality
Old Mar 21, 2008
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
Re: Front tow hook?
i thought benen tow hooks just bolt up to the original tow hook
Old Mar 21, 2008
1sykcivic's Avatar
RHCP0801 is my hero
Re: Front tow hook?
it is for looks like everything else on the outside of the car. I already have it so HAS TO GO ON lol
only for the rear
lol, i dont want to cut into my bumper. Only thing i can think of is finding 2 long bolts so it comes out of my lower grill
Old Mar 21, 2008
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
Re: Front tow hook?
ricer.. jks
and for the one who said about drilling through the rebar, good luck, they are usually made from ultra high strength steel, you'll be going through at least 5 drill bits to get a hole
Old Mar 22, 2008
chkolny's Avatar
chkolny will become famous soon enoughchkolny will become famous soon enough
Re: Front tow hook?
rrrriiicccerrrrrr
Old Mar 22, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: Front tow hook?
^^ you just jealous you dont got a front tow hook. i am. lol.. tow hooks look bad ***
Old Mar 22, 2008
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
Re: Front tow hook?
They are for more than just looks. If your car is lowered or you have a low hanging lip, and you have to get it pulled up onto a flatbed tow truck, the angle of the cable would be too steep. You could run the risk of ripping off your bumper cover, lip, fogs, ect... I have the 05-06 A-Spec lip kit on my Type S, and the instructions tell you to remove the whole bumper cover when getting it pulled up onto to the truck. If you get one, try to find the style that lets you place it pointing down when not in use. I think it looks better.
Old Mar 22, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Front tow hook?
Your cars don't have tow hooks? Mine does. It's behind the bumper, I saw it a few days ago when I was under the car looking for a jack point.
Old Mar 22, 2008
modoman's Avatar
Re: Front tow hook?
Originally Posted by rice4lyfe
ricer.. jks
not really. it's not "ultra high strength steel", in fact it's probably a bad place to mount it anyways, as you could risk serious damage to the front end of your car, i'd only imagine. but anywho, i drilled through that thing using a standard bit designed for metal (about $15 from home depot) when i mounted the ballasts for my hid's. but i'd recommend not putting it there. and, like dex, i too have a tow hook on the front of my car.....
Old Mar 22, 2008
roll_outz's Avatar
roll_outz is an unknown quantity at this point
Re: Front tow hook?
It should be way under your frontbumper cover. ASk kiril(MAZDAKIRIL) He got tow hook on his 7th gen. tow hook Is not only for looks its give you lil clearance for those people who park in front or behind your car.
Old Mar 22, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Re: Front tow hook?
Originally Posted by chkolny
rrrriiicccerrrrrr
QFT.
That's as bad as race graphics on a street car.
Why don't you install some neons while you're at it?
Old Mar 23, 2008
1sykcivic's Avatar
RHCP0801 is my hero
Re: Front tow hook?
Originally Posted by Unevolved
QFT.
ok wise guy
ill keep my comments to myself
Old Mar 23, 2008
Unevolved's Avatar
Re: Front tow hook?
Am I wrong? You said it's going to be for looks only.
Old Mar 23, 2008
mazdakiril's Avatar
mazdakiril is an unknown quantity at this point
Re: Front tow hook?
hey i got the rear tow hook but not the front, there was a guy on here that had a front one but cant remember his name.
let me get this straight tow hook = ricers, if thats the case you guys are more lost then president Bush.
Old Mar 23, 2008
Unevolved's Avatar
Re: Front tow hook?
No. You're absolutely wrong. Tow hooks are legit, and make a track car look badass.
But when they're purely for cosmetic reasons, well... It's like fake mud on a 4x4. Just plain wrong. It's very literally a poseur: "a person (or car, in this case) who habitually pretends to be something he (or it) is not."
Like it or not, if you put a fake towhook on your car, you are a poseur by definition. It's not a matter of opinion or looks at that point.
Old Mar 23, 2008
DeX's Avatar
DeX
Canadian, Eh!
Re: Front tow hook?
Come on, it's no worse than putting carbon fiber on a car that doesn't see the track. I feel the same way as you with the tow hook but no need to call him names. Just tell him nicely it's dumb and he'll be embarrassed when other knowledgeable people try to talk to him about it......
Old Mar 23, 2008
Unevolved's Avatar
Re: Front tow hook?
OK, I think that'll be fine. Maybe we should just let him get laughed at hardcore by guys with real track cars.
To the OP:
Good idea. Go for it.
Old Mar 23, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Front tow hook?
You'll find a lot of track cars not using those metal hooks. Most use cables or canvas straps, because they're flexible and dont jam into things, not to mention if they're not sticking out, you dont slam your shins on them.
those benen type things are more or less a looks item, you dont see many of them on the cars at the track.
Old Mar 25, 2008
mazdakiril's Avatar
Re: Front tow hook?
well then i dont know what to say other then i'm only for looks, have the tow hook and the carbon fiber, I dont have any intrest to take my car to the track as a matter of fact i dont even take my car past 125 km/h and dont take my rpm past 3600rpms,
I dont think you guys should be judging people on the fact that their cars arnt track car.
Old Mar 25, 2008
Unevolved's Avatar
Re: Front tow hook?
I would say, by definition, you're a poseur. It's not a matter of opinion, it's a simple fact. You can choose to be offended or not, it's up to you. Just with the way you built your car, that's the category you fall into.
Not to inject politics into this, but if you're not even from America, why are you comparing me to my President?
Old Mar 25, 2008
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
Re: Front tow hook?
I feel stupid for reading this entire thing thinking that somewhere in this mess there might be a real answer or solution to a front tow hook but instead its mostly flaming. The only person that put anything legit in here was Boilermaker. Anyone have a solution to the front tow hook?
Old Mar 25, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: Front tow hook?
i asked a guy at a car show with one on his 7th gen...
you have to drill a hole or two through the metal bumper support
Old Mar 25, 2008
DeX's Avatar
DeX
Canadian, Eh!
Re: Front tow hook?
In my attempt to contribute for anyone asking in relation to legitimate track purposes, are you looking to install the hook in the OEM place behind the bumper or to have it sticking out through the bumper?
Old Mar 25, 2008
cinaibur's Avatar
Re: Front tow hook?
another thread lost to bs bickering
Old Mar 25, 2008
Unevolved's Avatar
Re: Front tow hook?
This is true. It seems this is a well-known effect known as "ImportPassionism." When there is a lack of material substance or intellectual stimulation on any given website, bickering and off-topic responses begin to fill that void. It's a fact of nature.
Old Mar 25, 2008
cinaibur's Avatar
Re: Front tow hook?
all i'm saying is that he asked how/where to mount it and it turned into another who's the biggest ricer pissing contest. this website is here for people to ask questions and for knowledgeable answers to those questions. if he wanted to know what you thought about his tow hook, he would have asked, and probably before he decided to buy it
Old Mar 25, 2008
Unevolved's Avatar
Re: Front tow hook?
But if he didn't want people's opinions, why would he post it on an open board on the internet? Surely he's not that stupid, that he didn't realize his question was very truly "open to the public."
Old Mar 25, 2008
PitchBlack's Avatar
Re: Front tow hook?
Unevolved dude take this **** somewhere else and lets keep this on topic. Front tow hook anyone? Answers only, opinions are like *******s, everyone has one.
