downshifting question
Old Mar 18, 2008
bluecivic_19's Avatar
bluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the rough
this is a noob question but im a self taught stick driver and i never really got around to askign bout this.
when shifting down from 4th to 3rd, can u skip 3rd and go to 2nd. or is skipping gears downshifting really bad?
Old Mar 18, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Re: downshifting question
Skipping gears isn't a really good idea shifting up or down.
My buddies Camaro makes him skip 2nd gear when he is getting on it, which I always thought was weird. I assume it's because his transmission is designed that way.
In any case, and if I'm wrong I'm sure I'll be corrected, but I think downshifting is hard on the tranny anyways, downshifting 2 gears is just that much harder and I think skipping gears when upshifting kinda hurts the clutch a little bit.
I guess the only time I would consider this is if I was going down the highway, had to slow wayyyy down to like 10mph for a deer crossing the road, I might skip it down to 2nd, but at that point the engine has slowed way down too.
And if you are downshifting to brake, . Just get better brakes they are cheaper and easier to fix than trannies and clutches.
Old Mar 18, 2008
Alex857's Avatar
Alex857 has a spectacular aura aboutAlex857 has a spectacular aura aboutAlex857 has a spectacular aura about
Its fine just make sure your not goin like 40 mph cuz at that speed a downshift would be revvin 2nd till like 4500 or 5k lol. Other than that, i think you should be ok.
Old Mar 18, 2008
Murderjetz's Avatar
Murderjetz is an unknown quantity at this point
yeah last night I was driving in 5th, I was slowing down, once I hit about 80km/h I went to shift down to fourth but I missed it and accidentally went into second. not good....it was revving at like 6000 RPM and I didn't know what the hell was going on.
but I've only been driving stick for a few days. I hope I haven't caused too much damage with all of my stalling and jerky shifts. getting considerably better though!!
Old Mar 18, 2008
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
doing it once "shouldn't" hurt your trans, just try not to do it too often. I mean even people that have been driving a manual since they were 16 still miss shifts, its gonna happen, just don't make it frequent.
Old Mar 18, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
i always downshift to slow down, daily driving. cracked my tranny case open not long ago and everything looks as healthy as if it had zero miles. clutch still looks brand new and has like 70k on it. just blip the throttle a bit and try to rev match.
Old Mar 18, 2008
Murderjetz's Avatar
can you explain exactly where is the clutch? and how can I tell if it's damaged or not?
Old Mar 18, 2008
you have to pull your transmission away from the engine to look at the clutch.
Old Mar 18, 2008
wellington's Avatar
wellington is an unknown quantity at this point
i have accidentally done it a couple of time :P
i am an idiot, however.
What do you do when you are going in 5th gear, then slow down to cruise around a yield? I always push the clutch, push the brake, then pop it in 2nd and cruise on through.
Old Mar 18, 2008
sl33pyriceboi's Avatar
^thats fine......just dont drop ur clutch or else ur gonna blow ur redline....
and its also a good idea to know what the RPM will be at different gears on different speeds...
^if that makes sense to you...
so when you down shift, you should try and revmatch that RPM to take some stress off ur transmission....
Old Mar 18, 2008
im a pretty agressive driver and i downshift ALL the time..not just "once is a while"
im at 95k miles and my engine is still awesome.
(but then again, i take care of my car very well)
Old Mar 18, 2008
Murderjetz's Avatar
is it bad to be pressing the clutch about halfway while giving it a bit of gas if I just wanna creep up slowly? I heard that holding the clutch too much is bad but I don't know how else to just creep along at a very slow pace. That is the only instance where I do that though so it's not all that often...
Old Mar 18, 2008
nah, that's okay if you're talking about taking off from a stop or a slow speed. it's bad to RIDE the clutch, like drive with your foot on it a bunch.
Old Mar 18, 2008
Murderjetz's Avatar
sweet, gotcha.
Old Mar 18, 2008
ONE7thREBUILT's Avatar
ONE7thREBUILT has a spectacular aura aboutONE7thREBUILT has a spectacular aura about
You can shift from any gear to any other gear as much as you like. Problem comes when your RPM and speed don't match. Also driving with the clutch not fully in or out is always a bad idea (unless in neutral of course).
Old Mar 18, 2008
sspem2's Avatar
em2
your doing it all wrong. Granny shiftin' not double clutchin' like you should.
Old Mar 18, 2008
Are we talking about making a car last or racing?
Old Mar 18, 2008
Wait a minute I'm talking about my civic not my CBR.
Old Mar 18, 2008
I hope that made absolutely no sence.
Old Mar 18, 2008
its ok. but when ur shifting gear, like 1 to 2 etc... ALWAYS PRESS UR CLUTCH ALL THEY WAY...dont half it...
Old Mar 18, 2008
Makes just about as much as double clutching a car makes.
Old Mar 18, 2008
08 r6 woot woot
Old Mar 18, 2008
thanks guys, so its not a good idea lol. another question, can u change the accuall gears (replace it with a new gear) if their grinded up. say u just wanna change 2nd??
Old Mar 18, 2008
Alex857's Avatar
you shouldn't creep along slowly while holding the clutch in....thats bad bad bad. For you that said it was ok it ruins that one thing called a throw out bearing and isn't good for your pressure plate either...I did it when I first drove my stick and now even at idle it chirps kinda..its hard to explain the sound.
And to answer your question yes, but very pricey though. You'd be better off getting a used tranny from a junkyard.
Old Mar 18, 2008
do you drop your clutch every time you take off from a stop?
Old Mar 18, 2008
Alex857's Avatar
haha no no but I'm saying don't like ride it. Sorry man I read fast and thought he meant like drifting around in gear with the clutch pedal pressed. Thats my mistake. Not saying I do it all the time but yes I have dropped it lol
also I have a bad habit of pedalling my car from a stop (like not giving steady fuel but more like brum brum brum as I let the clutch out lol). My clutch and pressure plate gives me fits when they warm up lol.
Old Mar 18, 2008
you know whats my worst habbit???
whenever im at a stop on a upward hill, i always rock my car up n down..... hahah im sure its eating up my clutch like mad.
Old Mar 18, 2008
Alex857's Avatar
yeaah thats horrible lol but its alright...don't stop till she slips! Hahaha
Old Mar 18, 2008
colourwolf's Avatar
colourwolf will become famous soon enough
noone mention Rev match?
If you rev match before u downshift, nothing hurts except you burnt more gas.
let say it is 1800RPM when u are going 60km/h @ 5th gear, now you want to downshift to 4th gear. Notice that @4th gear,the engine speed will be higher in order to go at the same speed. So you clutch in---->rev to 2000RPM----->downshift from 5th to 4th gear--->release the clutch.
If you do it right, u can even dump the clutch and will not feel anything.
Old Mar 18, 2008
Murderjetz's Avatar
yeah I've been trying to do that a little bit...tricky. I hope I can get it good eventually.
