downshifting question
Old Mar 20, 2008
  #61
yingjai's Avatar
yingjai is an unknown quantity at this point
Re: downshifting question
no one i know (as well as myself) downshifts in order to come to a stop (lets say going to a red light)
i just pop it in nutral and coast the way...and if the light turns green before i stop, i just shift it in a lower gear that is suitable and goooooo......
ur not an automatic, you dont needa shift down when ur bout to stop....
i find that downshifting helps slowdown the car a little on flat road. wouldn't it help take a little load off the brake pads?
Old Mar 20, 2008
  #62
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
I downshift when I need to slow down a little bit, or very gradually, but if it's a hard stop, brakes ftw.
Old Mar 20, 2008
  #63
Murderjetz's Avatar
Murderjetz is an unknown quantity at this point
Correction: brakes + downshifting FTW!!
Old Mar 20, 2008
  #64
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
Just REV MATCH and downshift and you'll be fine. I do it all the time
Old Mar 20, 2008
  #65
Mr_Plenty's Avatar
as a matter of fact i even downshift to first gear lol...kids dont try that at home....i only doing when im going less than 5mph tho and im coming to a complete stop
Old Mar 20, 2008
  #66
yingjai's Avatar
downshifting to 2nd gear is good enough for me imo. you can even accerlerate from standstill in 2nd at a decent rate... unless you're going uphill.
how do you prevent the slight jerk when you downshift? i was only taught the very basics by my friend and was left to learn the rest alone.
Old Mar 20, 2008
  #67
Unevolved's Avatar
Rev match.
As you put in the clutch, blip the gas to make the revs jump 1-1.5K as you let out the clutch. As you do it right, the engine will match the gearbox and the jerk will be eliminated.
That's what causes that slight jerk, when the engine's not turning the right speed.
Old Mar 20, 2008
  #68
yingjai's Avatar
what if ur braking and downshifting. how do you blip the gas then? heel?
Old Mar 20, 2008
  #69
Alex857's Avatar
Alex857 has a spectacular aura aboutAlex857 has a spectacular aura aboutAlex857 has a spectacular aura about
you let off the brake for a sec, blip the throttle, and brake again.
Old Mar 20, 2008
  #70
bluecivic_19's Avatar
bluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the roughbluecivic_19 is a jewel in the rough
heel to toe, right foot on the brake, clutch it, slide the heel to the gas blip it with ur heel and then realse the clutch.
Old Mar 20, 2008
  #71
heel to toe my friend, theres no need to let go of the brake at all
Old Mar 21, 2008
  #72
yingjai's Avatar
something new to practice lol
Old Mar 21, 2008
  #73
yea, its not that hard. u just need to get use to using all three pedals at once, and also make sure u dont wear big *** sneakers cuz then it'll be hard to tell how much ur blipping the gas cuz u cant feel the damn pedal lol.
Old Mar 21, 2008
  #74
yingjai's Avatar
you ever try driving barefoot? i think i had to move my car once without any shoes and it was awkward...
Old Mar 21, 2008
  #75
Murderjetz's Avatar
I'll try to make this more precise for you. This is probably different depending on the car, but as a reference, I drive a 2006 DX-G.
Let's say i'm in 5th going 100km/h and I wanna slow down. when I hit 90km/h, I downshift to 4th and bring my RPMS to about 3000RPM, because I know that going 90 in 4th gear will have my RPMS at 3000. Then once I hit 70km/h, I shift down to third, once again bringing my RPMS to 3000, for the same reason. I just memorized what speed i have to be going in which gear for my RPM's to be at 3000, just to make it easier to remember. and also let off the clutch slowly if you revved it a little too much or not enough, it will ease into the correct RPM more gently if you're not right on target.
I'm still kinda learning though, I haven't yet figured out at what point to shift down to second and first though. I often find it unnecessary though anyway, at this point I just go into neutral and just use the brakes.
Old Mar 21, 2008
  #76
Unevolved's Avatar
Size 13 feet make heel-toe in our cars damn near impossible.
JMKendrick
Sep 16, 2015 06:17 PM
tommycanada
Sep 5, 2015 04:59 PM
junkyardguy
Sep 2, 2015 06:07 PM
Kcpowerhouse
Aug 25, 2015 01:15 PM
martinsmartin
Aug 15, 2015 07:34 PM
