$50 Paint Job From Honda-tech
Old Dec 11, 2007
IrockCivics's Avatar
What do you guys think about the $50 paint job with a roller and other stuff? I'm really giving this a thought and want to try it on my civic.... I just wanna get some advice I'm low on $ so I wanna try some home remedy **** lol
Old Dec 11, 2007
HondaKorn's Avatar
Life is better with 5lug
Re: $50 Paint Job From Honda-tech
search! someone here is doing it now or is in the process of doing it.....lol
Old Dec 11, 2007
Civicman1988's Avatar
it looks good but i dont think i could do a 50.00 paint job on mine. hard call
Old Dec 11, 2007
Kevbotron's Avatar
I like my commute
do it up! I would if my civic was green
Old Dec 11, 2007
tuner04civic's Avatar
spell check pwns you
i know i was thinking about it for my 94 sedan.
heres some shots and the link for others who are interested.
http://www.honda-tech.com/zerothread?id=2034815&page=1
Old Dec 11, 2007
u rolling it on like u paint a house?
Old Dec 11, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
how is it done??
Old Dec 11, 2007
Spikez1222's Avatar
Spikez1222 is an unknown quantity at this point
Ya, I'm quite curious also... this sounds like it could go wrong though...
Old Dec 11, 2007
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
your supposed to sand, tape, and do all the other prep work. you just roll the paint on, then your done. thats the imppression i got. i guess you can do a clear coat as well.
Old Dec 11, 2007
haha wow im sorry but that is too obvious looking at the car its like they painted a wall in the living room. its not even glossy at all.
Old Dec 11, 2007
DsevenEm2's Avatar
This is Myspace
^ cuz theres not clearcoat.. at all.. they wanted a flat look for that civic from what i heard
i heard its very possible.. all in the prep work.. but i duno.. i wouldnt try it
Old Dec 11, 2007
mr_fobster's Avatar
doesnt look that bad, i think i might do it....not on the civic but on my corolla oh yea if you keep reading that almond white eg posted up there was painted by a gun.
the one rolled has some semi clear in it. looks better than that eg up there.
Old Dec 11, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
you can DEFINITELY make it glossy. there are so many threads about this on other car forums. i think it's a badass idea if you're on a budget and dont mind doing a **** ton of wet sanding.
Old Dec 11, 2007
sl33pyriceboi's Avatar
yes, but u know what happens to paint w/o a clear coat?
...it goes to **** in a few months....starts chipping, UV damage...etc
Old Dec 11, 2007
CivicHatch9one's Avatar
7th gen old timer.
CivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond repute
i wouldnt do this to my 91 ....... the bumpers will chip... its not flex paint. the second that bumper bends that paint is coming off.
Old Dec 11, 2007
KCblackVP's Avatar
KCblackVP will become famous soon enoughKCblackVP will become famous soon enough
I think the dull look is bad ***.. i kind of want to do it.
Old Dec 11, 2007
there are many who have done this and became skilled with experience....
quoted from other site:
"here's how i painted my car for about $50, it's actually very easy and the results are amazing. First off, get a can of tremclad real orange (or what ever color u want) in the can, not spray, yes tremclad, it is a acrylic/enamel paint which is very durable. next prep your car as if was any other paint job, fix all the rust, ect....no need to prime the car since the tremclad allready contains elements which allow it to be painted over bare metal. next, after prepping the car get a small 4" professional FOAM rollers, it's tiny and has one end rounded off, and the other cut straight, and is a very high density foam. u also need a jug of mineral spirits to thin the paint. The thing i really like about this is that there's no mess, no tapeing the whole car, just key areas, and u can do it in your garage, since your not spraying there is virtually no dust in the air, just clean your garage first, also it does'nt really smell at all, dries overnight and it super tough paint. also it you decide to paint the car professionally later, just prep and paint, there's no need to strip the tremclad. i have done this to a few cars, and i can say it works amazing, u just have to be paitient. next u thin the paint with mineral spirits so it just about as thin as water, a little thicker. get out the roller and paint away, don't get the paint shaked when u buy it, enamel is stirred, otherwise you'll have bubbles in the paint for a week!!! after u do 2 coats, wet sand the whole car, then repeat, 2 coats, wetsand, 2 coats wetsand. i painted the charger using a can since your not spraying the car u use all the paint and not spray 50% in the air, use progressivly finer sand paper each time. it's not really that much work, cause u can stop and start any time, u can do just a door, or the hood, ect. do one panel at a time, and don't stop once you start. once your done the final coat, wetsand with about 1000 grit to a totally smooth finish, and then using a high speed polisher i use a buffing bonnet and turtle wax polishing compound. do the whole car with this, and i'm telling u, depending on the amount of time and paitence you have, the results are amazing. laugh if you want, but for $50 ($30 for paint, about $20 for rollers, sand paper, ect...) it really looks good. also you can do these steps overnight, paint one evening and by morning u can wet sand. i have personally done alot of painting, mostly single stage acrylic enamel, and i've sprayed several cars in my garage with really good professional results, just it stinks, it's a real pain to do, easy to make a mistake, messy, and expensive. The tremclad is awesome paint, the "real orange" is an amazing hemi orange, and almost looks like it has some perl in the sun, awesome color right out of the can. I used this technique on my 1974 beetle also, here are the results:
http://i32.photobucket.com/albums/d1.../Picture10.jpg
the car before:
http://i32.photobucket.com/albums/d1...n/IM000475.jpg
another after pic:
http://i32.photobucket.com/albums/d1...n/DSC00164.jpg
here is a car i sprayed (71 beetle, midnight blue metalic):
http://i32.photobucket.com/albums/d1...n/DSC00194.jpg
here is the car before (71 beetle):
http://i32.photobucket.com/albums/d1...n/Picture1.jpg
here's a few pics of the charger done:
http://i32.photobucket.com/albums/d1...n/DSC02764.jpg
http://i32.photobucket.com/albums/d1...n/DSC02769.jpg
well that's my 2 cents worth, sorry for the long post. i was borred lol
i painted the orange beetle in 1999, and it still looks like the day i painted it, the 71 blue beetle i painted in 2000, and built the car for my dad, i used the same paint on my charger, maybe one day i'll spring for a good paint job, prepping is 90% of the work, stripping the car, sanding, ect.....painting is overrated!!!
So if you have TIME, then i'd say go for it, the worst that could happen is that it does'nt turn out and your out $50, but if your paitient, and expriement with lets say just the trunk pannel and if you like it do the whole car, if not just get it done by someone else for $4000. i don't know about you guys, but i would rather spend the $4000 on other parts like getting the mechanics sorted out and new chrome, cause when u have really nice paint and crappy bumpers, door handles it just sticks out more."
more photos:
and the forum that is dedicated to this method because this is truly becoming a very popular crazy and will prob hear a lot more coming up as soon as it gets out there more.
http://rolledon.forummotion.com/
and rep can always be appreciated!
Old Dec 13, 2007
I definately gonna do this... But I gotta search for the sand paper I need and other products. I might go gun metal of phoenix yellow.
Old Dec 13, 2007
good luck. and like i said chec the threads and they give you a list. i think the wagner paint gun was the best for this.
Old Dec 13, 2007
Thanks man
Old Dec 13, 2007
np bro
Old Dec 14, 2007
CaTacL1sm's Avatar
CaTacL1sm will become famous soon enoughCaTacL1sm will become famous soon enough
phoenix yellow ftw!!!!!!
Old Dec 15, 2007
Kwheels's Avatar
Kwheels is an unknown quantity at this point
a flat paint job looks good all depending on your choice of color...the white looks good...there are a few people i know who have done it and there cars come out pretty good for a do it yourself
Old Dec 15, 2007
I seen alot of people doing this but they all paint there cars white. I would like to see a yellow car but I think it havent been done that color yet.
Old Dec 15, 2007
from what i saw a majority do paint the cars white and red. i have seen some others like black etc. i would say look into yellow. would look nice with the carbon fiber and black wheels and how many of our gen are yellow.
the only pic of a 7thgen being painted i found so far.
Old Dec 15, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
why does he have a slide or die sticker on a civic?? and he should've done a better tape job or been more careful with the roller. props to him, cause i don't think i could have done this to my car...
Old Dec 15, 2007
Nick's Avatar
Formerly 2blu
Thats my car. Making the decision to paint it was easy. It was either rattle it, or roller. I chose the roller. I'm thinking about painting it again over christmas break.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ken4444
Sep 30, 2015 07:37 PM
carid
Sep 28, 2015 10:13 AM
