is this the right part i need?
Old Mar 21, 2007
thisaintgino's Avatar
thisaintgino is an unknown quantity at this point
i just got the koni yellows and ground controls. i was planning on installing the setup with a couple of friends but looking at the spring install diy on this site it said that i need to use the factory bearing ring from my stock shocks. without it ill hear those nasty clicking noises. i dont have my stock shocks anymore so im plannin on buyin just the part and i wanna know if its the right one. its #9 on this site for the parts. or do you know anywhere else i could get it for cheaper. thanks
51726-S5A-701 BEARING, FR. DAMPER MOUNTING... is this the right part??
http://www.slhondaparts.com/browse.a...talogId=14S5P0
Old Mar 22, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Re: is this the right part i need?
You don't have stock shocks, so what do you have? More than likely the bearing is on the shocks you have now. And #9 is the bearing.
Old Mar 22, 2007
i got my suspension put on by wheelworks along time ago. i have on tokico blues and skunk2 coilovers. i have a clicking noise everytime i turn. i took it back and looked to have to checked and they said i needed some type of bearing. i guess they didnt put on the factory bearing onto the tokicos. and i dont know where my stock shocks are. i was plannin on buying the part. but just wanted to make sure its the right one
Old Mar 22, 2007
bobsagator's Avatar
I didn't think you could install shocks/springs without the bearing. The clicking noise you have may be a bad bearing.
When I replaced my stock shocks my car had 75k miles on it. So I replaced most of the rubber pieces. Then I read about some cars with higher mileage having the bearings go bad after upgrading the shocks/springs. To avoid having to take it all apart again later, I just replaced the bearings too.
Everything kinda points to getting new bearing just in case, especially for just an extra $40.
mohawkboom
67
Aug 25, 2015 12:28 AM
Tim1959
Jun 3, 2015 08:15 PM
juror
May 26, 2015 06:35 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
