Steering Wheels Shaking At 60mph ++
Old Feb 15, 2007
IrockCivics's Avatar
Today I had to take my mother to work so I took the highway and since the streets were badd because of the snowfall and my car is too low and I notice when I past 60mph my steering wheel starts to shake alot anyone knows why? I open my hood and had madd ice in the bottom of the engine could that be it? I took the street home and damn I was plowing everything and I could feel all the hard show under my car as I drove. What could it be? Thanks.
Old Feb 15, 2007
spoonEM's Avatar
omgwtfbbq mod.
Its your alignment. Get an alignment and get your tires re-balanced and that will get rid of it.
Old Feb 15, 2007
Kevbotron's Avatar
I like my commute
ehh I think you have snow and ice buildup in your wheels and axles, that storm was a beoch! Take it to a car wash and jam the high pressure washer in there and spray that mother out... This is probably the solution if you haven't noticed shaking before the storm
Old Feb 15, 2007
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
if you got new brakes then its your brakes.
Old Feb 15, 2007
eugthebear's Avatar
eugthebear is an unknown quantity at this point
prolly not the brakes cuz he said it shakes when he accelerates. i like the snow buildup theory.
Old Feb 15, 2007
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
get your wheels balanced. if your braking and your steering wheels shakes then your rotors are warped.
Old Feb 16, 2007
xschizx9's Avatar
xschizx9 will become famous soon enough
yea, normally it's snow, I know I get a ton of snow in my rims... it sucks.. but hey it's winter.
Old Feb 16, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
clean all your snow/ice...it will make a difference...its cold here.
Old Feb 16, 2007
ncirom2003's Avatar
new brakes cause shaking huh?
anyways its possible that it is your brakes if your rotors are warped from overheating, to identify this problem, under moderate braking the shaking will get worse. it could also be any of your wheels bent from a pothole, and your tires possibly wearing irregularly.(due to alignment) so go make sure you dont have alot of ice stuck in your front rims causing an imbalance and then decide if it gets worse under braking, if neither of those is the problem go get an alignment and your tires road-force balanced.
Old Feb 16, 2007
2K5CIVICBOY20's Avatar
2K5CIVICBOY20 is an unknown quantity at this point
its most likey the snow stuck under there dude, it could also be your tires. Since its been freakin freezin out...your tires freeze up from sittin all nite. they get like a flat spot (from where the sat all nite or day..)..but it tends to go away after driving it around for a while. it warms up the rubbers. so it goes back to normal. but yea..clean that snow off first, drive it see how it feels. be careful spraying off your car..with this cold weather. make sure you drive it as soon as you do..dont let it sit for to long or other parts will freeze up. seen that happen alot
Old Feb 16, 2007
2k1_Stockie's Avatar
2k1_Stockie is an unknown quantity at this point
^ Dang... hes smart! haha
Old Feb 17, 2007
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
ITS SNOW JUST STOP PACKING IN THE SNOW WHEN UR STUCK!! SO DONT GO CHANGING UR BRAKES SUSPENSION WHATEVER ITS SNOW....thank you
Old Feb 17, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
i had this problem too, i also thought it was wheel balance, but it was outa nowhere.
I brought my car to the carwash and everythings fine now.
Old Feb 17, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
so what was it? like what did u do?
Old Feb 17, 2007
dru106's Avatar
ThE CoRRupToR
common sense OWNES you lol.....
Its either snow build up inside the wheel or most likely outta balance!!! Come on ppl!!!!!
Old Feb 19, 2007
HondaLuver's Avatar
Its a celebration bitches!
could be a blown shock
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
brennov8
Jul 13, 2015 12:57 PM
