K need help asap. How to remove wires from connector?
So im doing a cluster swap and I have to rewire the connector. but I dunno how to get the wires out? can someone explain to me in DETAIL how to go about doing so? ive tried pulling the wire, using paper clip, small screw driver...but i dont think im using em properly?
can you refer to this pic
and tell me EXACTLY what to do
and tell me EXACTLY what to do you mean u pushed them out from the end with the tiny little holes (the end u cant see in the pic) if so, where did u push em, directly in the middle? a lot of force? cuz i tried that and nothing. even tried pulling the wires with full force with a pliars, nothing.
i think if you look at the clips from the front you will see tiny little hooks on top of each clip holding it in.. you will need a needle to push that thing up while you pull the wire out
trust me, i tried. i dunno wtf im doing wrong. id push the paper clip as hard as i can get it in, then pull on the wire pretty damn hard. nothing budges. i broke like 3 paper clips aswell (to give you an idea of how hard i was jamming those suckers in there)
Hes probably at the shop asking them how much it is to pull the wires out right as we speak.
He'll probably come back with the tool because they shop guy didnt want to rip him off like that
^^ lolll actually i was at the shop 2 hrs before ur post :P
the shop guy said they dont do that, its not meant to be done, if u **** it up its scrap etc
then i went to my local electronics store, explained my problem (even brought a similar connector to show them) and they said they dont have the tool there, just to use a small screw driver
what i wanna know is, is the clip to the wire like a metal piece, one end the wire is connected to, the other end has a piece sticking up n out holding the wire, so u cant pull it out and in order to remove it you need to push that piece and then the wire should come out no prob?
i ask because at school i found a connector that looked like a bigger version on the one in our vics, and thats exactly how those wires came out (and i was able to do em with a paper clip
) Go to a local hardware store and pick up a "pick tool set".
They should be around $5 (US) and I think you can even get them at Walmart in the tool section. They are really nice to have in your home toolbox. There's a really thin and sharp one you can use to pry up the little retainer than will let you unclip the pin from the plastic holder.
I work w/ electronics and use these at work all the time.
OK OK OK I GOT IT DONE FINALLY lol
TOOLS NEEDED: a paper clip(the larger ones that fit right in the hole)
ok so after playing around with the clip for a long time and not understanding how to do it i finally got it...and its so easy...
if you look in the first pic thats posted you will see:
1. the wires are entering the connector
2. the portion of that connecter that you press on when you want to remove the connector from the gauge assembly...
the edge that you press in(when you want to remove the connector) actually comes out...or sort of clips out.. from the end of the connector if you look in the pic you will see that its already out)
if you still cant see it, try to watch your connector and the picture at the same time...
both ends on the backside of the connector can be "clipped out/popped out" (just tryna use words that describe exactly what happens)
you just have to use your finger nail or something to push the edge back (where the wires are entering the connector)and then a sort of forward up motion and the back clip portion pops out allowing you to be able to see the clips.... if you get this done simply stick a paper clip in the hole that you want a wire removed from and it pops out!!! simple and plain...
so when your connector looks like the one in the picture posted you use your paperclip from the front of the connecter (where it plugs in to the gauge assemply) and it pops out
thats the best description i can give without taking pics...its easy just hold the connector in your hand and observe it well and you'll get it done...
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
Blazz
May 25, 2015 10:56 PM
Dmitri
123
Oct 13, 2005 08:01 PM
