pistons????
Old Nov 2, 2006
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
pistons????
im gonna be bossting soon guys. looking to go with stage 2 crower cam turbo spec ans spring retainer. also looking for pistons. whatcomp should i be 9-1? where can i get these form fo rmy 04 civic ex coupe.. correct me if 9-1 is wrong for me. i think that is what boosted car woudl need.
Old Nov 4, 2006
????????help me
Old Nov 4, 2006
CIVDAWG21's Avatar
CIVDAWG21 is an unknown quantity at this point
go to PROCIVIC.COM you'll find everything you need there
Old Nov 4, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
search?
Old Nov 4, 2006
CIVDAWG21's Avatar
you can get 9.0-1 pistons for $435 and it comes with rings @ procivic.com
Old Nov 4, 2006
check dezod?
Old Nov 4, 2006
yamahaSHO's Avatar
yamahaSHO is an unknown quantity at this point
9:1 is about as low as I would go. In addition, if you're looking for pistons, I'd look at upgrading the rods and crank as well. I'm sure the rods i this motor are tiny, but I'm not sure on the crank.
If those cams are made for NA power and have a lot of overlap, I would suggest NOT using them with boost as you'll be letting boost escape out of your exhaust.
Old Nov 4, 2006
Logan3024's Avatar
Originally Posted by bOoStEd042dr
check dezod?
When are you Dezod fanboyz going to learn that he is just an overpriced middleman?
HwN, For all you d17 needs i would recommend race engineering
http://www.raceeng.com/pc-7902-55-ho...ton75mm91.aspx
these are the same ones dezod sells for 100$ more.......
Rods?
http://www.raceeng.com/p-7177-crwr-b...a-17-d17a.aspx
Again dezod is allmost 100$ more, not including your gonna get riped a new one for shipping.
Just lending a helping hand
Old Nov 4, 2006
Civicman1988's Avatar
Rods?
good site was going to by my head parts from dezod but this place is cheaper
Old Nov 6, 2006
hey guys .. whatis the stock compression on my 2004 civic ex coupe??????
Old Nov 6, 2006
ronaldo9's Avatar
9.9:1 fyi
Old Nov 6, 2006
tanks bro..
naokigoffi
Aug 30, 2015 06:19 PM
totravska
Aug 30, 2015 12:02 AM
MamaBear2015
Aug 22, 2015 05:27 PM
Butterfli13
Aug 12, 2015 11:04 PM
Grey
30
Nov 16, 2002 12:59 AM
