Something wrong! PLEASE HELP
I Hunt Goats, Rams, And Mustangs.
well af ration went into the 8's? That means you went lean or rich? and you said cyc 1 and 4 have no compression? If you went lean even for a second you run the risk of buring holes in your pistons, frying your rings, and even cracking the block... if your rich well then why.. What were you doing on the dyno if you only have (Mods- Wheels,tires,indiglo Gauges,cold-air And Custom Exhuast). There no sence in that. I mean how were you "Tunning" your car? When was the last time you changed your Timing belt?
Ashho-san 7thgen Ninja
I'm not surprised that they are trying to amke you pay. They scrwed up my clutch relpacement and told me it was cause i brought them an aftermarket clutch with a bad release bearing. Bastards still wont fix it.
ricer_em2
May 11, 2016 08:09 PM
pilebuck13
Sep 21, 2015 10:45 PM
