Head lights, cat questions
Old Sep 2, 2006
Dancj2's Avatar
Dancj2 is an unknown quantity at this point
Smile Head lights, cat questions
OK so i want to bake my head lights apart and take out the orange refector.
This is a 03 civic ex 2 dr, Has it been done, can it be done?
If not can i put the new civic headlights on w/out the refector?
I also want to replace or gut cat, will it throw a code, is there a o2 sensor there?
Thanks
Dannie
Old Sep 2, 2006
TheSmuggler's Avatar
Both answers are yes You cant ake the amber reflector out, as alot of people have done, and you will throw a code unless you get an o2 sim.
Old Sep 2, 2006
yea you can take the headlights apart or buy some. there are so many different kinds, all clear, blacked out, projectors of all kinds,
Old Sep 2, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
ebay.. search "civic 03 headlights"
Old Sep 2, 2006
Dancj2's Avatar
does anyone have so pictures of the stock light w/out the refector?
i want to know if its crome under there, or nasty?
Dannie
Old Sep 2, 2006
http://www.7thgencivic.com/forums/sh...d.php?t=155290
its chrome underneath.. that link actually tells you step by step on how to take that amber piece out..
Old Sep 2, 2006
i think it would look better with the reflector removed. it is just chrome underneath. the clear reflector looks weird. when you take the amber piece off, the reflector almost falls out, theres just one tab holding it on. but technically you should know that law requires you to have orange reflector and orange turn signals. most cop wont care about the reflector. and if you want 7443 amber bulb, there is one seller on ebay that has really good ones.
Old Sep 3, 2006
Dancj2's Avatar
cat
so back to the cat question. I want to gut it out. Will it throw a code?
what can i do about the code if it does?
Would it be better to get a high flow?
or a peice of pipe to replace the cat?
thanks for the feed back
Dannie
Old Sep 3, 2006
yes it will throw code. just get random tech hi flow cat cause it still passes smog.
Old Sep 5, 2006
Test pipe and o2 sim ftw
Old Sep 6, 2006
Dancj2's Avatar
o2 sim
o2 sim? Is this a fake o2 sensor that plugs in or a diode?
LInk on where to get?
Dannie
Old Sep 6, 2006
casper electronics used to make it, idk i think most of those place are not around anymore. try ebay? there are different kinds, i think some mechanical and others like a chip or box that fools the ecu into thinking smog is okay.
thana
Jun 15, 2020 07:05 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
cazminn
Nov 9, 2001 11:18 AM
sonsonzai
Nov 4, 2001 12:52 PM
