To remove, or not to remove...that, yeah is my question (pinstripe)
Old Aug 24, 2006
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
First of all I would like to ask people with red 'vics to post if you don't have pinstriping... Then my question is, is it worth it to remove the pinstripes...as far as potentail paint destruction...work...looks. I like things...plain/simple and am thinking I want to do this but am not sure...lemme know what ya think...
Old Aug 24, 2006
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
well ive still got my pinstripes, and i like them. actually had them redone when my car went to the body shop after my last accident. If ur having the car repainted, it might be worth takin them off, but doin it urself seems like a pain in the ***
Old Aug 24, 2006
skoot's Avatar
skoot is an unknown quantity at this point
take some wd40 on a rag and get the stripe real wet with it..then peal...It will come off in sections and take a long time. When your done use a clay bar to get the extra sticky stuff off
Be sure to wax the part you got wd40 on because it takes off everything
Old Aug 24, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
If you have a hairdryer (this time of year, you only need this if you live in the arctic circle) and fingernails, then you have the required tools to remove the pinstripes. I did mine back in January, and with a hairdryer it took all of 2 minutes per side to remove them. In the summer, you honestly probably won't need it. After removing them, I'd wash the car and wax over where they were.
Old Aug 24, 2006
RHCP0801's Avatar
i would remove them but yea just use a hairdryer and your fingernail, should come off fairly easy
Old Aug 24, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
i removed mine with just my fingers. no heatgun or hairdryer. the only problem i see with your car is its red. if the car is old enough and seen enough sun, the stripes will show. a buddy has a black s10 and took his decals off the tailgate and you can see it. i took my stripes off like 2 days after i got the car, but mine is white though.
Old Aug 24, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
the pinstripes are actually a bitch to remove....go to an automotive store...probably have to try a few....ask for a pinstriping remover wheel....its like an eraser wheels that burns away as it takes off the stripe...i believe most are clear coat safe too....imo its the only way to do this
Old Aug 24, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
take it off!!!
Old Aug 24, 2006
Hurts2bStock's Avatar
Shinier than yours, meatbag
what he said^^^
Take um off.....
Old Aug 24, 2006
They're a bitch if they're not heated up at all. Honestly, all you need is a hairdryer, If anything.
Old Aug 24, 2006
^^^dude....all the haridryer did when i took mine off was melt the pinstripe and leave adhesive...if you have a new car it may be easy but i did mine after a year and it was impossible without the pinstripe remover wheel
Old Aug 24, 2006
Mine's a 2001, So age is not the problem. If you hold it right up to the pinstripe, then yeah, you'll melt it. If you heat up about a 6 inch strip at a time from about 8 inches away and peel slowly, then you'll be fine
Old Aug 24, 2006
el ray's Avatar
el ray is an unknown quantity at this point
Take em off pin stripes dont belong in a vic
Old Aug 24, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
I used some goo gone on my pinstripes and heated them up pretty good. Fingernail works good too.
Old Aug 24, 2006
RedDragon333's Avatar
I would remove em. I have a red 01 and i like the clean uninterupted lines of the body
Old Aug 25, 2006
So I guess removal it is, thanks for the advice!!
Old Aug 25, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
dang i should take mine off now
Old Aug 25, 2006
Speaking of waxing, that's one of the reasons I was considering this, i'm getting a lotta wax build-up on the pinstripes...gets kina annoying trying to clean it out!
Old Aug 25, 2006
genexrocket's Avatar
off..
Old Aug 25, 2006
WELP, I dun it. Not as subtle of a difference as I thought it would be...It doesn't look like the car is cut in half anymore. As far as paint difference, I think the only colors that'd have to worry are dark, aka black. My car's roughly 3 years old, waxed at least 3 times a year and I do not notice a difference in color. I also used wax to remove the sticker residue. So I guess I wanna thank you guys for the motivation!!
oneheadlight
Apr 29, 2015 11:30 PM
Civicchik01
Dec 7, 2001 06:33 PM
viper775
Nov 15, 2001 10:54 PM
TaiChi
Canada West
Nov 8, 2001 01:21 AM
GabberHead
Bolt-on Engine Performance
Nov 6, 2001 10:53 AM
