how to adjust sensitivity on viper alarm 791xv??
Old Aug 13, 2006
RHCP0801's Avatar
i just got my viper 791xv installed today and its not sensitive at all, i am able to rock my car back and forth and punch it without any noise at all. I bought this alarm mainly because i heard its very sensitive....so does anyone know how to adjust it to make it a lot more sensitive?? oh and yes i searched with no results
Old Aug 13, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
there's a little clear box w/wires coming out that has a dial on it.....hope that helps
Old Aug 13, 2006
RHCP0801's Avatar
ahhh yes i saw that clear box, let me go check now
ok thanks thats where it was +1rep
Old Aug 13, 2006
how sensitive did you set it?
Old Aug 13, 2006
billiardini's Avatar
billiardini will become famous soon enoughbilliardini will become famous soon enough
unfortunately this alarm does not have the option built in directly on the remote like the viper 5000.. To adjust the alarm your gonna have to probably check under your steering wheel.. you should have a little module that looks like a clear, small plastic cube.. In the clear cube you have a white screw I believe.. Your gonna have to turn this screw with a mini screwdriver or any small mechanism that will fit clockwise or counter clockwise( check your manual im not sure which way you have to turn for it to be more sensitive.) Once you do that, wait a minute, than bang a door panel and you should see instant results.. hope it helped..
Old Aug 13, 2006
RHCP0801's Avatar
the max im guessing, it wouldnt turn any more
and billiardini the screw is yellow...ill rep you too
i hit it a little and it went off, tapped the trunk after that and it warned me
Old Aug 13, 2006
Suzy Q's Avatar
2 cups sweety 8 cups bitch
Suzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond repute
you can rep me too
Old Aug 13, 2006
RHCP0801's Avatar
i did already but ill do it again
Old Aug 13, 2006
ian01ex's Avatar
ian01ex is an unknown quantity at this point
Sweet, I wanted to make mine more sensative but had no idea. Thanks for indirectly answering my question everyone!
Old Aug 13, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Dude you punched your car? WTFack is up with that? Who won?
Old Aug 13, 2006
RHCP0801's Avatar
hahahaha i would rather me punch it to see if the alarm worked than some assh0le punch and it not go off
Old Aug 13, 2006
Very true.
Old Aug 13, 2006
ian01ex's Avatar
Ok I just did mine too. Turns out whoever installed the alarm had the shock sensor ziptied to a bunch of cables... I dont think any "shocks" would travel too well through cables so I attached it to the framework of the dash and turned up the sensativity. I am very pleased with how it works now. Thanks again everyone!
Old Aug 13, 2006
Civicman1988's Avatar
i did mine to thanks
Old Aug 13, 2006
D5cIvIc's Avatar
so which way did you guys turn it to make it more sensitive?
also, does anyone know how to program the alarm where if the warning tone is set off 3 times or more the alarm goes off? i can make my car warn me forever with the proximity sensor, but it won't go off.
Old Aug 14, 2006
ian01ex's Avatar
I turned it clockwise to make it more sensative. And the only way I know to make the alarm fully sound with a proximity alarm is to adjust the inner zone further out so that if they get too close it will go off. I have mine set so that there is a warning blip and then if they go to try to look in through the window or anything that close it goes off entirely.
Old Aug 14, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
take it back to who installed it and im not gonna bother readin the other post and hopefully nuttin bout bein emo
Old Aug 14, 2006
RHCP0801's Avatar
i figured it out already
Old Aug 14, 2006
ian01ex's Avatar
My answer was for d5civic. I know you allready got yours working.
Old Aug 14, 2006
RHCP0801's Avatar
i wasnt talking to you, i was talking to djrabbi
Old Aug 14, 2006
D5cIvIc's Avatar
+rep for the help
Old Aug 15, 2006
ian01ex's Avatar
No problemo.
wingsfan19
Oct 1, 2015 03:45 AM
frank_kleng
Sep 29, 2015 10:55 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
