jdm fenders with side markers
Old May 17, 2006
mugenman's Avatar
"mmmBAHHHH" - vtec y0
ok so i was looking on passwordjdm and i came across these
http://www.passwordjdm.com/product.a...For=&PT_ID=258
1st of all are these worth it? and how are the jdm fenders different from the usdm fenders. im thinking about gettin these. cause i now have a hook up on paint so it wouldnt cost me much to get them painted. so what do you guys think?
Old May 17, 2006
dirtySAMURAI's Avatar
I log in from time to time
i would say it's not worth it unless your fenders are dented/broken right now.
Old May 17, 2006
mugenman's Avatar
yeah but im nervous about cutting into my stock ones to make holes for the side markers.
Old May 17, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
DIY!!!!!!!!!!!!!!!!!!!!!!!! it's not that bad
Old May 17, 2006
mugenman's Avatar
i usally do alot of diy's but im just nervous about this one. altho i was nervous about blacking out my headlights but i just did it anyway
Old May 17, 2006
ramcosca's Avatar
Words on a User Title
Only difference: hole for sidemarker. That's about it. Not worth it if you've not crashed recently.
Old May 17, 2006
Hayz's Avatar
dont be a puss DIY I did it and If I can then so can you
Old May 17, 2006
Em2onCPRs's Avatar
DU MA Con Cac
Em2onCPRs is an unknown quantity at this point
i dont think the fenders from pjdm.com is real jdm fenders.. i bet its an aftermarket fender with sidemarker cut to fit the lights..in the paragraph it states its a jdm style fenders..
Old May 17, 2006
ramcosca's Avatar
Makes sense.
Old May 17, 2006
ncirom2003's Avatar
i was very nervous too, but its easy and just remember measure twice, cut once. youll be happy in the end, and thats a rediculous waste of money to buy those.
Old May 18, 2006
mugenman's Avatar
ok ok ill do it my self....only cause hayz did it. and if he did it it must be easy ill be pming you soon for some detailed instructions lol
Old May 18, 2006
ncirom2003's Avatar
measure on the fender using the body line and edge of the fender as reference points, find a spot you like them in and measure that on the other side too, now trace the sidemarker, cut the hole maybe 1/8th an inch smaller and pop in. there is a good DIY article on here.
Old May 18, 2006
i didnt even measure really. just cut a hole, stuff it in, and make sure its level with a bubble thing. drill in the middle first, then use sheet metal nibblers to cut out around it. i went too much on one but its not really noticable. just make sure they're not crooked.
Old May 18, 2006
X0DuZz's Avatar
umm....yeah?
X0DuZz is just really niceX0DuZz is just really niceX0DuZz is just really niceX0DuZz is just really nice
diy if u mess up buy those on the site ahaha
Old May 18, 2006
DrivenEM2's Avatar
DrivenEM2 is an unknown quantity at this point
good luck bro...im thinkin bout cuttin a hole myself
Old May 22, 2006
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
dremel tool worked great for me. I was scared at first but once you get used to cutting that gaping hole you relax. The first hole took me like 45 mins the second was like 15.
Old May 22, 2006
03hce's Avatar
03hce has a spectacular aura about03hce has a spectacular aura about03hce has a spectacular aura about
Good question mugen, was wondering the same thing. Was going to get the s2k sidemarkers from that site... let me know how it turns out and let me see how they look!
Old May 23, 2006
CivicHX01's Avatar
paragraph says they are "JDM spec" usually pwjdm will say "genuine JDM" if its real... so i'm guessing they are USDM fenders that have been professionally cut using a template from the JDM fenders...
but hey, its the closest thing to JDM without getting the actual fenders overnight shipped from Japan...
Old May 23, 2006
mugenman's Avatar
lol oh i will man.....soon as you dirve your goofy *** down to cincinnati
im jus gonna order the sidemarkers and pray to god i dont f*ck it up!
Old May 23, 2006
oi2325's Avatar
oi2325 is an unknown quantity at this point
It would be a waste of money buying an oem fender with a hole premade in it when you can get the light for what, 30 most
Old May 23, 2006
cbuncivicman's Avatar
cbuncivicman is an unknown quantity at this point
JDm fenders
I work at a body shop/collision center. I write the estimates and work in the office. But, if you get the fenders and just paint them, you will probably end up with a color difference between the fenders and the doors. No matter how much we color match the paint it is always slightly off because there are so many variables that can cause a color difference. (i.e. air pressure, the painter, humidity, etc.). Sometimes the color will look right when looking at it straight on, but when yo check the "side tone" from on an angle the color can be off.
P.S. I cut my fenders to install mine, not that bad.
Old May 23, 2006
TheSmuggler's Avatar
OK, whatever you do do NOT buy these fenders. I got them and they were all warped. Save yourself the trouble and either
A) Cut your oems
B) Get some fenders from the coupes in Europe (stock sidemarkers)
Old May 23, 2006
03hce's Avatar
lol... who you calling goofy!
Old Jun 7, 2006
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
did you order the sidemarkers and the harness or just the sidemarkers? cuz i was thinking about getting those too but then i just decided when i get home from deployment (less than 3 months) i'm gonna order the sidemarkers and maybe the harness but i want to know if the harness works for our cars or if they are for the ep3. i know the site says jdm ep3 sidemarkers..blah blah blah. well post a pic and what not when you get done with them! good luck
Old Jun 7, 2006
no the harness doesnt work because we dont have sidemarkers! so harness is useless. mine came with one and its just sitting in the engine bay somewhere. i should've just chopped it off.
Old Jun 7, 2006
HondaKorn's Avatar
Life is better with 5lug
they also had fitment issues....ask smuggler
Old Jun 7, 2006
Fitment = crap
Old Jun 7, 2006
oh ok thanks gearbox... you always come thru. hey smuggler, you saying that the ones from password jdm are crap as far as fitment? in what way? where do you recommend me getting them from? thanks ya'll i appreciate it!
Old Jun 7, 2006
I recommend you either cut your OEM's, or try to get your hands on some fenders from a coupe in europe
Old Jun 7, 2006
Kizuel's Avatar
Kizuel is an unknown quantity at this point
Yeah, just DIY, it's not as bad as it seems, only took me about an hour.
