car has gone under the knife!!!!
Old Mar 9, 2006
ncirom2003's Avatar
aww dont look sad, it will only hurt for a second...............
SCALPAL!!!!!!!!!!!!!!!!!
going in, t25 turbo kit (FMIC), emange, boost controller,turbo timer, act stage 1 clutch (need better soon :bash: ), rsx injectors, ground wire kit, motor mount inserts, arp head studs with nippon leakless gasket, stage 2 turbo cam, spring/retainer upgrade, civic ex VTEC head with a port and polish, hid's, oil pressure gauge to go along with boost and a/f, maybe my lip kit and repaint/reclear car.
shooting for 250whp expecting 240ish. but with this clutch ill have to turn boost down alot till i get a new one.
Old Mar 9, 2006
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
lookin good bro
Old Mar 9, 2006
s0ltker's Avatar
- hella tite y0 -
s0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nices0ltker is just really nice
awesome keep us updated
Old Mar 9, 2006
ncirom2003's Avatar
ill do my best, right now the issue is the clutch, once i get that squared away ive got no worries. i really hope the tranny and axles hold up well. and ill be back with some dyno sheets within a week cus its getting dyno-tuned and then on the 18th is a local car club dyno day so maybe ill turn the boost up a bit for a run or two. track times sometime in april.
Old Mar 9, 2006
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
unless you got yoru heart set on act, look at spec for a clutch. i got a stage 2 for 295
what did that setup cost you anyway?
Old Mar 9, 2006
ncirom2003's Avatar
what do you mean, look at spec? and whats better than act? more details needed lol
ummm turbo used off here for 1700, all together all the parts i bought excluding lip kit about 43-4500 and thats with everything(other tahn turbo) at about a 35% discount from msrp cus i got connections lol
Old Mar 9, 2006
nice!
Old Mar 10, 2006
drew22mader's Avatar
There is gl@ss in my @SS...
hell yea man, keep us updated and good luck!
Old Mar 10, 2006
ncirom2003's Avatar
im hoping on alot of progress tomorow, my father (who i work for) is letting me work only on my car, i will only stop when he absolutely needs me to do something.
Old Mar 10, 2006
FuzzBeC00L's Avatar
Fuzzy Boy
nice bro
Old Mar 10, 2006
Ashhole's Avatar
SPEC is a company that does clutches. if you go to www.horsepowerfreaks.com and go under civics you'll see 'em
Old Mar 10, 2006
turboengnr's Avatar
DONT PANIC
looking good! Cant wait to see the results
Old Mar 11, 2006
ncirom2003's Avatar
me either, update later today, im tired right now.
ok update,
today wasnt too productive cus i was feeling kinda sick in the morning then had to run errands for my father.
called machine shop and the cylinder head wont be done till monday morning, big set back.
i got the manifolds off and out of the way, dropped the exhaust, got the accesories off and timing belt off, then removed the head, i put in the kms block guard and to make up for the difference in hole patterns between the head gasket and block guard, i set it in about 1/4"-5-16" so theres a pocket where the coolant can pool up and go wherever before the headgasket. oh and i put in the polyurethane motor mount inserts.
now- pics! yay
Last edited by ncirom2003; Mar 11, 2006 at 12:20 AM. Reason: Automerged Doublepost
Old Mar 11, 2006
turboengnr's Avatar
DONT PANIC
that block guard and install looks quite familiar....
Looks awesome!
Old Mar 11, 2006
hmm those block guard holes seem kinda small.
Old Mar 11, 2006
turboengnr's Avatar
DONT PANIC
theyre small, but there are a lot of them. By putting the block guard down below the deck of the motor, you are allowing the water tho have a passage to the ports on the head after it goes through all of the holes. If you simply put it level with the deck, you would only have 4-5 of those small holes feeding the cylinder head.
Old Mar 11, 2006
cj2185's Avatar
cj2185 is an unknown quantity at this point
nice
Old Mar 11, 2006
ncirom2003's Avatar
mwahahah our block guards own! i knotice u have a d16, did it fit fine? they sent me a d16 and i returned it for a d17.
gearbox they are exactly 3/16", i tried drilling extra holes but wanst too succesful with the drill press so before i screwd it up i called taht quits and just installed it.
Old Mar 11, 2006
turboengnr's Avatar
DONT PANIC
the D16 one fit fine once i modded it. All i did was take a large flapper wheel and bored it out larger. Fits perfect now.
Did you have to do any sanding?
Old Mar 11, 2006
ncirom2003's Avatar
nope none at all, i put it on and it kinda went in but it was tight, so i busted out the 2x4 and a rubber mallot, didnt take much effort to get it in good.
Old Mar 11, 2006
turboengnr's Avatar
DONT PANIC
i guess that was the only difference. I had a 5" flapper wheel, and i put it in my drill press and went to town...
Old Mar 11, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
nice.
Old Mar 11, 2006
ncirom2003's Avatar
today was a mellow day, i took it easy and laid back a bit. i finished installing my boost gauge and installed my oil pressure gauge, i also got the damn rear motor mount insert in, and mounted the FMIC. i think im gonna mask off the word civic with the last c backwards and paint it black.
Old Mar 17, 2006
ncirom2003's Avatar
update, no new progress really, monday my grandfather who im close to was rushed to the hospital, ive been spending my spare time with him, wed. he passed (thank god it was peaceful and painless), i will resume after the wake and funeral. maybe sunday or monday.
things i did get done here and there.....
installed my new train horn, painted civic on the FMIC (it looks good, not ricey i think), installed rsx injectors, picked up the head-looks great now i gotta re-assemble it then the engines ready to go together again!!! yay, other than that a bunch of small things and electrical stuff is left.
Old Mar 17, 2006
turboengnr's Avatar
DONT PANIC
sounds good man!
Ive been getting a few things done on my car too.
I just got a Tial 44mm wastegate today, and ordered a Tial 50mm BOV.
Im trying to get mine running by the end of next week. It would be funny if both were up and running at the same time.
Old Mar 17, 2006
ramcosca's Avatar
Words on a User Title
Wow. Now that's clean. What you bumping up to?
Old Mar 17, 2006
ncirom2003's Avatar
sounds good!
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
