LED gauges - MY WAY!
Old Mar 3, 2006
  #31
the stock bulbs put out very little light in the blue spectrum. for leds, hot spots are easy to remove. or you could get a bulk EL sheet and put it BEHIND the cluster for backlight.
Old Mar 3, 2006
  #32
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
let us know when you get it working gear. I am in need of a kit. I tired the LEDs diskreet recommneded and half of them started flashing in and out and stopped working all together eventually. So I have stock bulbs glowing w/o the stock film and it looks pretty terrible
Old Mar 3, 2006
  #33
i am starting a unique project for someone. just got a pack of PINK leds ordered so i am gonna retro them in the cluster to get everything lighting up good. you guys can always send me your cluster for around $100 I will do a complete led retrofit in the color of your choice.
The alternative for you since the gauge is cleared already is put two layers of red or amber taillight repair tape on the back of the cluster and then put small pieces of paper where the hotspots are. use the stock bulbs. but that only works for two colors.
Old May 3, 2006
  #34
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
any idea if this method would work for 04 and newer models, since i remember gearbox had issues while working with a newer gauge setup.
Old May 4, 2006
  #35
the new gauges cannot be taken apart and put back together with everything working. End of story.
Old May 6, 2006
  #36
Civicman1988's Avatar
best link ever
Old May 15, 2006
  #37
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
maybe ill do this now.... i thought it was too much work before...
Old May 15, 2006
  #38
its actually not that hard to put more in there. Just drill, use some epoxy, and connect them all together. comes out nice and bright. i've done some of these in a few days non stop. just takes time and patience.
Old Sep 27, 2006
  #39
sl33pyriceboi's Avatar
not bad..........but may i suggest you to shave ur leds flat......so you will have a more spreaded beam pattern......
.......so u wont have so much hot spots
Old Sep 27, 2006
  #40
for me it doesnt matter, theyre easier to mount without shaving, and theres a led behind each number so the light is evened out that way.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
frank_kleng
Sep 29, 2015 10:55 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
