Painting Help
Old Jun 19, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
Painting Help
Today i stated painting the fuse box and the valve cover, I bought American Tradition plastic enamel. Figured it would work cause i'm painting plastiuc well i was wrong. What kinda paint did evey one else use, if any 1 has any sugestions. please help
Old Jun 19, 2005
YUL's Avatar
YUL
YUL has a spectacular aura aboutYUL has a spectacular aura about
did u sand it down and prime it b4 painting it?
Old Jun 19, 2005
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
no need to sand, just primer. To get that off, get some aircraft paint remover. 1. primer, 2. paint. And dont spray as much as you did before.
and try to pick a better color
Old Jun 19, 2005
ajhdragon's Avatar
7thgens official a$$hole
use light coats man way to heavey you can always add more but sucks to take off.
Old Jun 19, 2005
Changu-San's Avatar
Mr. Clean
you dont have to sand, but for best results and to have a smoother look, you should sand, prime and then paint. remember to keep can at least one ft away from whatever you're painting so that you apply the coat evenly.
Old Jun 19, 2005
manahoonie's Avatar
agree... too thick for the first coat. go slowly...
Old Jun 19, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Aircraft stripper is NOT plastic friendly. You're pretty much going to have to sand it off. Lots of things could have caused that but here's some of the leading ones...
1. It was dirty
2. Use used paint that was designed for wood or some other very porous medium
3. You didn't clean it (its in an engine bay, oil and dirt out number clean parts)
Either get it off, or buy another one, clean it with soap and water, let it dry, douse it in alcohol and let it air dry, then paint it. I've never primed mine and it sticks, but you might want to take some sand paper and roughen it up a bit first.
Old Jun 20, 2005
Thanks for the info, I'll sand it down should i'll use wet and dry if so what grit ? What the best paint and primer to get and where should i get it from ?
Old Jun 20, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ Get something that is heat resistant from your local auto store!
Old Jun 20, 2005
R1Style's Avatar
omg lmao
looks like the plastic was wet when you tried painting it.
sand that sucker down, wash it with mild dishsoap and lots of water. Then prime it and paint it... when you prime and paint... do extremely light coats.
Old Jun 20, 2005
ya i will ce more carefull this time. Gonna have to wait a few days. I'm getting my chevelle ready for GM nationals at carlisle, and i'm installing my evo cf hood today.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
