removing dash pieces
ok so how does one remvoe the vent sin the dash by each door?
do i jsut yank them out?
04 DX
and that part aroudn the gauges.. i see the two screws upt op.... do i unscrew them and jsut pull it out also?
any help would b grea.t thanks!!!
04 DX
the vents on the side you just yank out. You can do it with a flat head screw driver. Just be careful not to mess up the vinyl. If your talkin about the center piece with the air condition *****, then yeah you have to unscrew the two bolts on the bottom and carefully yank it out with a flat head.
yeat tilt the vent portion up and get a grip and pull and it should pop out. OR ... open the door and on the side of the dash is a triangular panel that pops off, use a flat head screwdriver thats really small with a rag on the tip and pry one side to pull the rest, then just push the vent out.
Around the gauges has a glue so its gonna feel like you breaking it or missing a screw but just yank upward and it should come out. After removing those 2 screws up top ofcourse.
mohawkboom
67
Aug 25, 2015 12:28 AM
EdGasket
May 25, 2015 01:06 PM
cooldan1
Apr 23, 2015 10:49 AM
Dmitri
123
Oct 13, 2005 08:01 PM
