Oven Temp
Old May 19, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
Oven Temp
I was wondering what temperature to heat the oven up to when clearing my headlights. I've searched but nothing.
Old May 19, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
Broil.
j/k I think I remember hearing 250. Good luck and post pics when you finish. I plan to do this sometime this summer.
Old May 19, 2005
Akutenshi's Avatar
The Rizing Sun
275 is good.
Old May 19, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
I did 225 and it was kinda hard to pry apart...soo probably like 245 - 250 should do u good.
Old May 19, 2005
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
none... it took me 10 minuts to split them with no heating. never knew why people even reccomended that...
Old May 19, 2005
How long do you leave it in for? I will be doing it this weekend.
Old May 19, 2005
Karumba's Avatar
Boredom causes changes ;)
Sedan and 04/05 lights have a stronger/thicker sealant around the bead.. easier to get apart with heating. Coupe 01-03s shouldn't be a problem with no baking - might need a blow-dryer to help along, but nothing too drastic. As for why on earth this post is in Member's Rides rather than say "Lighting" subforum And I'm almost certain you can find an answer in that section as well..
Old May 19, 2005
orion_squall's Avatar
I believe it is better to use hair blower. You will have more control.
In the oven you might have the risk of discolor the chrome.
Old May 19, 2005
Boggie1688's Avatar
Diamond Member
Yea my 05 was a bitch to get apart....
Old May 19, 2005
so just take the hair dryer around the outside and pry them apart, what kind of sealant do i need to buy to put them back together?
Old May 20, 2005
dirtySAMURAI's Avatar
I log in from time to time
all of this is covered in the sticky in lighting forum under the 04-05 headlight clearing thread.
anyhoot, use silicone. GE silicone II from home depot. $5 a tube.
hair dryer probably won't work and it will take FOREVER to heat up the headlight to the appropriate temperature. buy a heat gun (it will distort your headlight casing), or use the oven (risk melting your headlight casing). either way, if you mess up, you lose.
Old May 20, 2005
I would rather it take forever and get it done right then ruin my headlight by heating it up too hot. I may just buy new projector headlights.
Old May 20, 2005
exturbo6's Avatar
[QUOTE=BassKadett]Broil.
Old May 20, 2005
it will take 2 person, one is blowing and the other one pry. You will see that while you are prying, the gum would just separate itself from the heat. hehe
Old May 20, 2005
Karumba's Avatar
Yeah but infinite012, I believe he's working on doing his 02 headlights .. which should be a lot easier than 04/05 (and/or sedan headlights) .. in which case he might not need to oven-heat ..
In any event, I'd still say search the lighting forum and/or perhaps asking local regional members to Ohio for some assistance.
Old May 20, 2005
I'm going to have one of my friends do it, everyone says its easy for the 02, I hope i don't break em,
Old May 20, 2005
2K1Civic17"Gabe's Avatar
I just pried mine apart in the summer. on a nice 120 degree day they came apart nicely. I have an 01 coupe.
yeah, broil should work, or a brick fire oven. like a brick pizza oven, that will warm em up enough
Old May 20, 2005
Should i baste them? How do i check when they're done? Just put a thermometer in it?
Old May 20, 2005
hell yeah, when the juices are starting to run out, they're nice and tender, hehe
you know Im j/p right. DOnt want somebody to really go throw em in a oven like that, that would be funny to see a thread tomorrow, I baked my headlights and they burned up
Old May 20, 2005
Ohhhhh your just kidding? I just turned the over on and started to baste them, man now i have to wipe them, why didn't you tell me this earlier?!?!
Haha just playing, yea i knew you were kidding.
Old May 20, 2005
SeeGirLDrifT's Avatar
SeeGirLDrifT is an unknown quantity at this point
I heated mine up to 275 or 300 F, and then turned it off, and then put in my headlights. I left them in there until the oven cooled, and it was pretty easy. But yea, 01 headlights aren't hard to get apart.
Old May 20, 2005
scrimp's Avatar
scrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of light
Just use a blow dryer. U might need another person but its not hard at all. Its safer then the oven
Old May 20, 2005
02 coupe headlights are a cinch! just take a flat head screw driver to the inner corner (the pointy part that is furthest from the turn signal), pry the corner apart, then work your way around the headlight. if you need any extra help, use a cerrated (sp?) blade so that you can cut the glue before it separates into two long strands, thus landing on your chrome reflector piece and ruining your headlights.
Old May 22, 2005
Hey i finished up my headlights, looks great, i had help with the front bumper, didn't need to really use a anything to heat it up, nice hot day no humidity at all, used a generous amount of silicone to make sure they didn't leak, all in all it was easy and awesome.
I also ordered 2004 Stock Tail lights, got me a pair for 112.50, brand new he took them off because he puts ricer euros on his "show" car.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
cferry7
Oct 3, 2015 04:33 PM
srtlat
Sep 17, 2015 11:02 PM
Dave Brabant
Sep 10, 2015 06:48 PM
