I'm So Frustrated! Urg!
Old Mar 20, 2005
chicohonda02's Avatar
Since 2002 Baby!
Angry I'm So Frustrated! Urg!
Ok so you guys saw me putting in my new headlight bulbs on thursday, right. Well guess what f**king happened. I already have one bulb that went out. I am so pissed. Now you have to understand the situation. For the past 3 years I've gone through like 5 to 6 sets of bulbs. But what goes out is the lowbeam of the bulb. It just stops working. My highs work even on the bulb that goes out. I keep saying its a wire issue, but HONDA seems to tell me otherwise(that things are fine). I agree with people who have told me that HONDA is smokin crack. I don't know what to do anymore. I hate stock bulbs and refuse to drive with them unless emergency. I don't even think stock bulbs would matter.
What the hell do I do!
Old Mar 20, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
weird, i'm still on my OEM bulbs and i've had my car for almost 2 years.
Old Mar 20, 2005
There's a recall on the combination headlight switch. It can cause low beams to fail often. Get that checked asap.
Old Mar 20, 2005
Since 2002 Baby!
i HAD IT FIXED, WENT BACK TO honDA, AND THEY SAID THERE WAS NOTHING WRONG. Thye say is the bu'bs not wiring.
Old Mar 20, 2005
paradoxblue's Avatar
jsut go in and tell them it jsut fried your stocks
Old Mar 20, 2005
eklipz's Avatar
its the cheap "hid" bulbs...buy oem or a good brand like silver star...or if you want to dish out a little cash to get the good **** talk to impulse and get hids
Old Mar 20, 2005
skiboard's Avatar
first make sure rubber paddings are tight so no water can get in to the headlight &
Try doing grounding kit for your ride, I used to have this problem and after I installed a grounding kit and never burns out now
Old Mar 20, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
wear latex gloves when you install them. oils from your hand will make them burn out faster.
Old Mar 21, 2005
Whelan's Avatar
Whelan is an unknown quantity at this point
Go to this link
http://www-odi.nhtsa.dot.gov/cars/pr...callSearch.cfm
And follow the steps, then click on "print version" Bring that letter to your dealer and tell them you want it fixed ASAP. In some cases its the wire connectors overheating but they told me mine were fine. Well my issue with the headlights was not the bubl blowing out while on. It would flash out during turn on. I would turn the switch to turn on my headlights and the bulb would flash out. Its happened so many times it makes me sick. I had silverstars in there and it did the same thing, ugh ugh ugh. Ill be going to the dealership as soon as I get my stock headlights back in there cause this s*** needs to get fixed. Im not changin headlights every two months.
Old Mar 21, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
I was thinking the same thing. Often people are not aware of this. Any contact with your skin or other greasy dirt will make them burn out significantly faster.
runawaykinms
15
Mar 22, 2019 10:32 AM
mjdiaz89
Jun 21, 2016 09:26 PM
alinaray
18
Aug 24, 2015 01:04 PM
martinsmartin
Aug 15, 2015 07:34 PM
Green02civic
Jul 27, 2015 10:48 PM
