Installing Gauge face?
Old Jan 20, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Anyone know how to do this...How hard is it? Is there a DIY on this site that someone can point me in the right direction towards? Thanks
Old Jan 20, 2005
diskreet's Avatar
Ok ill make it easy...
1. remove the two screws above the gauges.
2. Pull on black bezel, but keep in mind its glued right behind the steering wheel so be careful
3. Remove the screws holding the gauge cluster in.
4. Remove wire plugs from gauge cluster, and pull out the cluster.
5. Unclip plastic cover, remove
6. Install gauge faces. Bend gauge faces, DO NOT MOVE/PUSH NEEDLES!!!!!!!
7. run wires out. I used a dremel to take a little off the lip on the clear cover to let the wires pass through.
8. Re-install clear cover. Plug in wires. Screw in cluster. Screw in bezel. done. yes its easy but intimidating if you never did anything like it before. Take your time.
Step 1 refers to the two screws on the very top left and right of the pic.
Old Jan 20, 2005
1. wrong forum
2. search for diy
Old Jan 20, 2005
hotrodcivic2004's Avatar
my civic has no boost
dont get intimidated by something uve never done before, we all work on our cars cuz its fun and we all learn thinigs bout our cars we never knew before. u might screw somethin up but it could ALWAYS be fixed, as long as u have the confidence go ahead and dig in. JUST DONT TOUCH THE NEEDLES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:e ek:
Old Jan 20, 2005
jeffsta17's Avatar
Does moving the needles screw up the reading they give?
Old Jan 21, 2005
civicvtec1ps's Avatar
Search and Learn
Umm, you HAVE to touch the needles to put gauge face in, just don't remove it.
Old Jan 21, 2005
I've had mine off 20+ times and they're fine for the most part. Better to keep em on tho, since there's no need to take them off anyway.
Old Jan 21, 2005
diskreet's Avatar
Honestly not unless you really move it hard or something, but its not worth the chance! Touch it as minimily as possible.
Old Jan 21, 2005
skipbarber's Avatar
you can move the needles as much as you need to...gas and temp have internal stops...don't test their integrity. Tach and Speed return to their position automatically. A good way to make sure the new faces wont stop the needles is to move them...if they dont go back to 0, you need to stick your faces down more.
racer28
Jun 19, 2015 02:35 PM
pratik05
May 15, 2015 01:54 PM
fordfocussucks
Nov 6, 2001 03:16 PM
WhosYoDadday85
Nov 3, 2001 11:23 PM
Mokushi
Nov 1, 2001 02:40 PM
