What Size Rims To Get?
Old Jan 11, 2005
KissMahWhiteAzz's Avatar
KissMahWhiteAzz is an unknown quantity at this point
Question What Size Rims To Get?
Stock 05 Ex Coupe.......What the best size rims to get if your lowering the car so it does not rub? 17's? Will it rub?.....Will 18's rub if not lowering the car?
Old Jan 11, 2005
CivicsRdBest's Avatar
it depends on how low you'll go. I'd say keep them small so they don't hinder acceleration or make the ride incredibly stiff, but if you're going for looks 18's are great.
Old Jan 11, 2005
baggedblue02's Avatar
baggedblue02 will become famous soon enoughbaggedblue02 will become famous soon enough
26's!!!!!!
Old Jan 11, 2005
HeHateMe's Avatar
HeHateMe is an unknown quantity at this point
Hi, I have 18" DUB Remix on my civic. It's lowered 1.4" with no rubbing.
Old Jan 11, 2005
sevgenic's Avatar
sevgenic is an unknown quantity at this point
I got 17's with a 2" drop and no rubbing.
Old Jan 11, 2005
jackal903's Avatar
jackal903 is an unknown quantity at this point
it depends on how wide of the rims
Old Jan 11, 2005
so whats a good width? 7.5?
Old Jan 12, 2005
Shlomo's Avatar
Shlomo is an unknown quantity at this point
its actually more of the tire width that you have to look for. i've got 17's with a tire size of 215/40. dropped with no finger gap, and no rubbing.
Old Jan 12, 2005
NightRider02's Avatar
sleekest 7th gen on the right coast
NightRider02 is an unknown quantity at this point
i'd reccommend 18's. it wont rub depending on how low you drop your car and what size tires you get. my car is dropped 2.5 inches, and i have 18's with 225/35/18 tires and it just clears it.
Old Jan 12, 2005
HondaGuy12's Avatar
Fiji Club Member
yeah u have a tight *** ride man..seen it on cardomain.com.. looks great..
what springs did u lower it with? any new pics?
Old Jan 12, 2005
arcalan's Avatar
arcalan is an unknown quantity at this point
18s with 215/35/18 wouldnt rub. I had a 1.5" drop, doesnt rub. Yeah 7.52 width should be good. They will affect your acceleration, but look great. Also if you use a tire as thin as 215/35 then your ride will be stiff as hell, you will feel almost every bump on the road
Old Jan 12, 2005
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
you should look at this several ways when deciding on what size rims to get! One 17's weight less than 18's and thats the last thing you want to do is make these tractors go even slower than they already do! Two 17's are smaller in diameter so that means you will be able to lower car much more than with 18's! About the only benefit that 18's have is that they look much better because they are obviously bigger! Now with certain profile tires you may experience rubbing with 18's! For example, i had 225/40 18's with stock springs and did have rubbing problems but only when i made hard u-turns! Thats not to say that yours will do the same thing! Everyone's car is just a little different! If you do decide to get 18's i would reccomend the 215/35 18's so that you have a slimmer chance of rubbing but that is just my opinion! i think the diameter of the tire is what causes most rubbing issues with our civics! Not a whole lot of 18's come in 7" width! thats where 17's become the better choice! now with thinner 18's you will be able to lower it just a tad more than with thicker 18" tires! But keep in mind that with thinner tires your rims will be toast if some potholes decide to come your way!
I hope this is of some assisstance to you!
Old Jan 12, 2005
HeHateMe's Avatar
Hey thanks man
I used Eibach Sportline 1.4" springs. I'm getting ready to put my body-kit on. I'll post more pic's soon.
Old Jan 12, 2005
Berg_Tomaru's Avatar
I suggest you to go with 17" inch wheels, it's more practical and still look nice To be sure whether it would rub or not depends on many factors such as the series of the tires, the width of the rims and the offset of the wheels. I use to put on a set of 17" * 7" wheels with 215/45/17 tires and +38 offset, it doesn't rub even with 4 passengers (lowering with Koni shcoks and Tanabe DF210 springs)
Old Jan 12, 2005
2K1Civic17"Gabe's Avatar
I love my 17s. I was gonna upgrade to 18s, but I will be changing color rims, with 17s. They ride good, they look good (needer a larger profile tire). You would be happy with 17s. Get a 205or215?/45/17 tire though. I have 40s and just needs to be a littler bigger. I am lowered about 2"s and I have never rubbed once. I have taken some speed bumps pretty hard when I didnt notice/see them.
I have 205/40/17 (17s) with goldline lowering springs, they save 1.75" drop, but I am about 2"+. From what I measured before and after (about 4 times each). I also have tokico HPs (blues). They make the suspension much stiffer, so you dont bounce around or blow your shocks.
Old Jan 12, 2005
Nice screen name, BTW
Old Jan 12, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Was slammed this past summer over 2", on 205/40ZR17 rubber (Kumho, bleh) 17x7 rim, I think the offset was 42, I forget. Never rubbed once, rear was tucked and front had 0 gap.
Old Jan 12, 2005
incubus7d's Avatar
I Wanna Die Like God on the Cover of Time!
incubus7d is an unknown quantity at this point
I got 15" SSR rims and im tucked on each tire, my car is real low
Old Jan 12, 2005
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
tein s tech and some nice 16" with 205-50-16 tires
Old Jan 12, 2005
SmiteSwift's Avatar
SmiteSwift is an unknown quantity at this point
Don't be stupid. Weigh your current rims with the tires with the correct air pressure, then buy any rim & tire combo that weighs less than stock. Your car won't need to work as hard to accelerate and brake.
Idiots out there getting 17s and 18s (read: heavier) are for show, and will be slower than stock.
Pay attention to unsprung weight. Always shoot for lighter.
Old Jan 12, 2005
HeHateMe's Avatar
lol idiots? That's what my Civic's all about man...SHOW!
http://www.cardomain.com/memberpage/749882
Old Jan 19, 2005
no more post? come on now i need help with picking out 18's or 17's and 7.5's..... 7's? Whats the best combination if not lowering it right now but might in the near future? If i do lower it can't u get the rims skinny enough to slide up in the fender well if i was to say hit a POT HOLE?
Old Jan 19, 2005
tnel2005's Avatar
tnel2005 is an unknown quantity at this point
17's 2 inch drop
Old Jan 20, 2005
Logan3024's Avatar
Chrome rims and carbon fiber hoods look rediculous, and those tail lights!!
Old Jan 20, 2005
Day_Tripper's Avatar
Owned By Slo Rex
same here
trust me you don't want anything more then 17" those slow me down enough
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
