Stupid Orange Odometer
Old Jun 17, 2004
sleapercivic's Avatar
sleapercivic is an unknown quantity at this point
I am looking at getting some new guage faces, but I was thinking about what I am going to do about the odometer. I don't want nice blue and red guage faces and that stupid orange odometer.
Does anybody know how to chance the color to red or blue, or any other color? Or, is there a replacement piece that I can purchase for it?
Old Jun 17, 2004
DizWikedCivic's Avatar
i like the color of our gauges, and it not orange, it amber
Old Jun 17, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
http://www.7thgencivic.com/forums/sh...hreadid=128559 check this link out.. its by gear box... you can change it to whatever color you want.. hopes this helps
Old Jun 17, 2004
I have seen that posting, but thanks for the link.
I dont think that he changed the color of the odometer, but everything else looks great.
Old Jun 17, 2004
Well changing it is tricky. The light has to be spread out or it will look uneven and weird. I couldn't do it right, so the easiest thing is just take out the bulb behind it. You can just twist it off from the back. Problem solved.
Old Jan 1, 2005
socalcivic02's Avatar
socalcivic02 is an unknown quantity at this point
gear box had something like that on his post for blue needles
Old Jan 1, 2005
Old Jan 1, 2005
Clay's Avatar
Clay is an unknown quantity at this point
http://www.kognitiondesign.com/index.html
This Site May Be Helpfull...
Old Jan 1, 2005
those are great needles, but how can i change the odo to blue
Old Jan 1, 2005
ImPulse's Avatar
They dont make them for our cars
Old Jan 2, 2005
Fluorescent needles aren't a new thing and actually it's a very easy mod.
1) use isopropyl alcohol to strip orange paint off needles
2) paint needles with fluorescent (glow-in-dark) paint of choice
3) install uv neon inside bezel below needles so light shines up
Old Jan 4, 2005
gearbox how did you turn your odo blue
Old Jan 4, 2005
It's unplugged. I don't want to mess with it and really it wouldn't flow with anything else.If you want try to clear the paint off the filter carefully with alcohol and put a blue led behind it. Maybe substitute paper for the filter, and maybe run some EL wire through the back to see if it does anything. Obviously, you'll have to take the cluster all apart and bend up the lcd without breaking it. I would not recommend doing this if you've never done it. You could try to just unscrew the bulb from the back of the odo without ripping apart anything and see how it looks with a light shining through. Again, you're just gonna have to try things because I haven't experimented.
Old Jan 5, 2005
jameStype's Avatar
jameStype is an unknown quantity at this point
i like the guages the way they are in the 04 coupes. it is cool though that they offer different solutions for the older civic gauges.
Old Jan 6, 2005
I think i found a solution, i was just in my friends 2004 dx sedan and she has all light blue dash including odo, so all i have to do is make sure that it is compatible, and find one.
Old Jan 6, 2005
zachgeyer's Avatar
lets send them some emial the might start
Old Jan 7, 2005
AlienX's Avatar
AlienX will become famous soon enough
if you really want to change it to a diffrent colour, you need to desolder the odo and clear the amber/orange paint for starters, then just install some LEDs behind there...
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
hondacivic0253
Sep 29, 2015 08:06 AM
Donahue
Sep 9, 2015 05:55 PM
msaeger
Sep 2, 2015 08:47 AM
