finally a dyno with the DH ported head.
sorry for the bad pic but I don't have a scanner around.
125.7 HP 109.7 TQ 2001 ex NA
see my profile for all mods.
its still running kinda lean in the lower rpm range. the VAFC2 was only able to add a little fuel.
The OBD2 kept recorrecting it. It did not knock even at 0 fuel. I ned to figure out how to add more fuel. there is still a bit of HP to be had at the lower rpm range. any ideas...other than piggy backs. whoah...that's perty cool...since stock ex's dyno in at around 104-106 whp (i think some1 posted a dyno with those #'s before...stock) correct me if i'm wrong... but taht's a nice gain!
Interesting. Someone mentioned an adjustable fuel regulator, but I don't know who makes them for our cars. AEM just has universal ones.
So the vafcII didn't really help?
Props
to you man. I glad someone finally posted a dyno. it would have been really cool if you posted a before and after, but no biggie. Hail to the fastest N/A d17 on this site...
Originally Posted by tiredwolf
Props
I think stock they get around 100 whp. If someone can find a link to a stock ex dyno let me know. All my mods are in my profile.
I have a before dyno but it is not exactly accurate as a before and after comparison. When I did that one I still had the KMS intake manifold on and did not have a hi flow cat. It was 113 hp and 96 tq untuned running very rich. The car pulls nicely but I wont be happy until I am at around 140 whp NA. I have to get more fuel in there before anything else. A cam or throttle body will just lean things out more. I wonder if a SF style fuel system will work on a NA car. Any fuel ideas/advice are welcome.
what was wrong with ur VAFCII??? Cause i'm going to get SAFCII and i don't want to buy it if that same thing will happen to me. i know couple of peeps that are boosting have there car tune with vafcII and its fine
aight coo thats good enough cause i have SF fuel system and 5point is good or i might even take out fuel cause i'm rich rite now. u might have to get bigger injectors that would help.
u could ask them cause as far as i know it adds more fuel to the stock ingectors when its sees boost. The more boost it sees the more fuel i get. so i don't know how they could work that out for N/A car.
this guy is selling his E-management and 440 injectors
http://www.7thgencivic.com/forums/sh...d.php?t=155556
Fuel pressure regulator isnt going to work if you want to add more fuel. Remember that the stock FPR is in the gas tank. This is why SF uses an inline pump to draw more fuel from the tank. If you want to add fuel you are going to need to convert to return or get an inline fuel pump. You can use an FPR at that point to control how much fuel you are dumping into the cylinders.
Good luck and good numbers!
Not really. Look at all his other mods. Still okay I guess. Oh so why did DH tell us we can just buy a fuel pressure regulator? I obviously believe Dober on what he says, so maybe DH just didn't know any better.
djmota, is this dyno after you had the cam gear and vafcII tuned?
Escaped Convict
good post.
dyno varies from one session to the next. there are many factors, not including temperatures, altitude and what not.
but generally a stock ex 5spd will run around ~110 whp. with torque around 105. both give or take 2-5 units.
Originally Posted by gearbox
So is there anything else we can do other than vafc and cam gear?
The cam gear stayed at zero. This seems to be the best setting. This is after all the fuel tuning we could get out of the vafc2. I was thinking... would larger cc injectors work? They would run rich but I could adjust that out with the vafc2. I thought about the return line, it just seems like alot of work, I wont do it unless I have to
I would be willing to throw some bigger injectors in the mix or possibly an inline pump with adjustable regulator to squeeze more fuel out of my stock injectors.
.I would be willing to throw some bigger injectors in the mix or possibly an inline pump with adjustable regulator to squeeze more fuel out of my stock injectors.
That dyno sucks. bluestrek made 125 whp on his EX with just I/H/E. I know because I saw it and have it on video.
