rsx seats question
rsx seats question
just received my rsx seats,
what mods do I have to do. I can now longer open the DIY from hondawerx.
can someone help me?.
I have already searched in this forum. I just want to know if I had to do something with the holes of the frontseats, maybe pics.
thanks.
thanks.
Its a celebration bitches!
get a dremel and dremel about 1/2 inch down. first bolt the rear holes down and align them. then pry the front holes down a little and then bolt those in.
and also connect the seat belts. which isn't too hard.
and the rear seats are a totally diffrent story( they are a bitch!!!), right now, i have almost all the peices to put the rear seats in so they will fold down. all i currently need is one hindge from acura. and i will be finished. too bad i wont be able to lock them... unless...
Do we HAVE to use a dremel (never used one) or can we just ause a drill bit..if so what size? Hondaluver...what do you mean by connect the seatbelts?
you can use either one, just make sure you grind the hole longer 1/2 a inch. and the person might not have included the seat belts on the seats so just transfer over you stock seat belt buckles. they are a direct bolt on, just one bolt and 3 wires to cut
NoobyKid
Jul 13, 2015 07:53 AM
Reppin Stage 7
