Vafc II is Installed!!!
Old Feb 28, 2004
  #31
ViNRoCk8's Avatar
#1 S2000 Fan
this vafc always has some problem, its never easy on our cars
but it seems like you got it to work
Old Feb 28, 2004
  #32
CarbonFly's Avatar
There is NO problem with the VAFC II on our cars. It works perfectly.
Old Feb 28, 2004
  #33
Yeah, I just installed mine. No cel or anything. You just use the wire diagram that Carbonfly posted in tech. Works perfectly, well with tuning of course.
Old Sep 22, 2004
  #34
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Gearbox, Can one of you guys that successfully installed the VAFC2 post some pictures of the wire connections to the ECU harness ? If you guys recalled, there is a DIY on the Apexi RSM "http://www.7thgencivic.com/forums/showthread.php?p=2042142", it seems the ECU wire you guys use for the Pressure Signal is used as the Speed signal wire in the RSM install. Can anyone of you VAFCII experts clarify this ? Also is there any total cutting of the ECU harness wire when installing the VAFCII or are the wires only tapped ? Thanks.
Old Sep 22, 2004
  #35
eklipz's Avatar
Red X i wanna see
Old Sep 22, 2004
  #36
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
garyc17: you have to cut into the vtec wire and the pressure signal i believe...i can't remember, too long ago...didn't ur v-afc2 come with instructions?
Old Sep 22, 2004
  #37
Hwoody77's Avatar
Hwoody77 can only hope to improve
Gary there is a DIY around here, BUT I believe a total of three wires have to be cut, VTEC, VTM, and Map sensor.
Old Sep 22, 2004
  #38
SomeDoodToo's Avatar
SomeDoodToo will become famous soon enoughSomeDoodToo will become famous soon enough
Originally Posted by CarbonFly
I have my vtec engagement set at 5600rpm. It's fricken amazing. I've never felt vtec engage before and how its like DAAAYMN!!!! My friend was riding with me and he said everytime I hit it, he was thrown into his seat. He loves it.
I know what you mean I put one in my ex's (gf at the time) rsx-s and had it dyno tunned....It was sweet when it would kick in expc with 191 whp it deff would put u in ur seat well when i would drive lol she wasnt that good
Old Sep 22, 2004
  #39
GaryC17's Avatar
Anyone can post pictures of the wiring diagram instructions provided with your Apexi VAFCII or the relevant pages needed. I only have the Jap version over here in my country which I do not understand. Thanks.
Old Sep 22, 2004
  #40
Civic6-Speed's Avatar
Civic6-Speed can only hope to improve
Well it took us about 2 hours to install. We soldered all the wires to make sure that we had great connections. I hope you like the spot that we mounted the unit in.
Umm you soldered wires to your ecu?!?!?!?! Yea thats really bad. You know how much heat goes through those wires when you solder them? I would not be suprised if you daamaged your ecu. But hell what do I know im just a newb, or so everyone says, ill prolly get flamed for this post too.
Old Sep 22, 2004
  #41
djmota's Avatar
well you said it.... Anybody doing this install should also be able to figure out that you unplug the ecu while you solder the wire
and just a note. You are soldering to the wire, not directly to the ecu.
Old Sep 22, 2004
  #42
Nitto's Avatar
gone
Nitto will become famous soon enough
dead pics! wtf
Old Sep 22, 2004
  #43
True you are soldering the wire but if you dont disconnect the ecu then you can have problems. so i was warning the guy. but ok you can be ignorant. Its what your good at.
Old Sep 22, 2004
  #44
Kenny's Avatar
Kenny is an unknown quantity at this point
I think you didn't connect the VTM wire, my have the same problem before, but if you put the VTM wire...the problem will be slove..
Old Sep 23, 2004
  #45
goodtimes's Avatar
if i had a shop do it all do you think it would be done right and with no CEL and have them set the vtec at 5200rpm's,O one more thing does anyone here have an auto and have the vafc 2 lnstalled on there car.
Old Sep 23, 2004
  #46
I have an auto with vafcII. It doesn't work on the newer ecus. I tried turning up the fuel, and it corrected itself in a few days back to stock.
And no, a shop will most likely fail the install. There are more wires that are not in the apexi diagram. We have all the info you need in the sticky thread.
http://www.7thgencivic.com/forums/sh...d.php?t=169767
Old Oct 3, 2004
  #47
goodtimes's Avatar
[QUOTE=gearbox]I have an auto with vafcII. It doesn't work on the newer ecus. I tried turning up the fuel, and it corrected itself in a few days back to stock.
so you are saying that it will not work with the auto ecu,and do you think it will be a good infestmint for me.
Old Oct 3, 2004
  #48
I'm not sure exactly, but it seemed like it wasn't doing anything. Only way to tell for sure is get it dyno tuned and go back there a year later to see what happened.
Old Oct 3, 2004
  #49
goodtimes's Avatar
do you think it would be a good investmint
Old Oct 3, 2004
  #50
Well it does let you monitor engine settings like rpm, voltage, throttle, etc. I wouldn't get it if you only have a few boltons. Might give 5whp if you're lucky when tuning it.
Old Oct 5, 2004
  #51
goodtimes's Avatar
well i want to pnp my head and i allso have cat-back,header,intake,pullies, grounding kit and denzo spark plugs.
Old Oct 5, 2004
  #52
Yah when i put it on my ex's type-s there was an extra wire or too but i found the info online it was awhile back.....But anyways... Did ur fuel go back b4 or after to added those two wires?
Old Oct 5, 2004
  #53
I can't tell without a dyno, but I doubt the tdc wire does anything important.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
