Just Gonna turbo Charge any suggestions?
Old Aug 2, 2003
2k187's Avatar
2k187 is an unknown quantity at this point
I haven't done anything to my car yet and it will still be a while yet, but I am just going to save for a turbo to put on my 01 Ex 5 speed, all my friends with their 13 second f-bodies say it is a waste, but I say that me spending so much on small things now would be more so. Any suggestions on how to get the engine ready for a turbo and what to use to back it up while under boost?
Old Aug 2, 2003
TRIPLExRATED's Avatar
TRIPLExRATED is an unknown quantity at this point
2k187-
I don't have a civic but I am in the process of turboing my miata. So good things to do to get it producing a high amount of boost with out messing up the motor is to add a high flow fuel pump, bigger injectors, add a stage 2 or 3 clutch and lighten the flywheel (if it is manual). Also you are gonna need a timing unit to retard or advance the timeing so you don't detonate. You are gonna want colder spark plugs and some better plug wires. Depending on the miles of your car and how good of a condtion your motor is you might want to build the motor for more power.
Hope that helps you out.
Old Aug 2, 2003
XxJDMCivicxX's Avatar
Depending on how much boost you plan on using I would suggest pistons, sleeving block, porting, injectors. That's if you plan to boost upwards 10psi. Just get SF turbo kit solves all the problems
Old Aug 5, 2003
Yeah, don't waste money on small mods that don't do anything. Also, adding a turbo will void your warrenty... that's why I'm waiting.
Old Aug 5, 2003
EnProceso's Avatar
i would still get an exhaust with the turbo, it will help the engine breathe easy
Old Sep 27, 2003
2k187's Avatar
Thanks for the help all, only prob with the sf thing is I dont know the price and I live way up here in tn.
Civic15
18
Sep 19, 2017 07:48 PM
Dani1993
Jul 24, 2015 09:02 AM
Nalmonte
Jul 22, 2015 09:08 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
manfredww1
Jul 14, 2015 10:24 AM
