sedan DIY dendener and leather insert
Thanks for the site I was able to remove then paint then put on leather door panel insert. This knowledge come from 1 month of reserch here and there on the site.
I also made really cheap personal deadeners.
3 layer-----> 1. foam (form bed) 2. rubber undercoating 3. rubber (from useless rubber mats)
I glue them individually on holes on our door panel and removed the factory white plastic sheet on panel.
I glue them using the same kind of glue Hnnda used for the factory white plastic sheet.
I add one layer of undercoat on the plastic door panel itself, and cover most of hollow using foam (from bed).
thanks for the information from this site.
hope you like my job listed here.
This belongs in members rides...Please look where you are posting before posting things...There are other forums other than general ramblings
yeah,
because I am not sure if the info here are good enough to go memeber ride section, so it stays at general talk for the moment.
I will see if people in general like the work then I will but pics on member ride...
thanks
thanks
tomas6791
Aug 22, 2015 12:20 PM
Touge
Aug 13, 2015 04:32 AM
mrohitredd
Aug 12, 2015 11:36 AM
Touge
Ottawa
Jul 18, 2015 05:39 PM
Touge
Jul 18, 2015 05:35 PM
