replacing automatic shift knob
1) buy a RAZO shift ****
2) remove stock shifter by removing 2 small screws on the backside of the ****...below the trigger button
3) follow the included instruction sheet to install
4) sip on some iced lemonade after 10 minutes of hard intense work.
U seriously want a DIY? Its probably the easiest thing to do...easier than pumping your own gas.
Open the car door.
Sit in the seat.
Unscrew the 2 screws.
Put on ****.
Secure the **** with what they gave you.
Drive.
Open the car door.
Sit in the seat.
Put on ****.
Drive.
i been looking around... i heard some people say you have to push down to shift gears if you change the ****... i seen pictures of ***** with buttons on it, would you still have to push down or just use the button?
What_It_Do
May 10, 2015 05:31 PM
