ECU Fried 7th Gen cars have a Chronic issue - alternator bolts get loose and the loss of grounding will eventually fry the ECU
04 Civic 1.7 L engine. Cannot read the OBD check engine light
Old Jun 14, 2021
tott2692002's Avatar
tott2692002 is an unknown quantity at this point
The check engine light is on so I went to Advance auto parts and Auto Zone. Techs plugged the reader and it cannot read the error. It’s just keep spinning forever. I read there may be a blown fuse. Everything works in the car.
Where is the fuse of the OBD? Any other stuff I need to look for
Thanks in Advance
Old Jun 15, 2021
BrotatoChip's Avatar
Super Moderator
Re: 04 Civic 1.7 L engine. Cannot read the OBD check engine light
Fuse 9 (10 amp) in the under-dash box is for the data link connector. If it were blown you notice other issues though. Does the temperature and fuel gauges in the cluster work?
Old Jun 15, 2021
Both Temperature and fuel gauges work or to be honest the needle moves. I’ll replace the fuse anyway and see
what else could be the reason ?
Old Jun 15, 2021
FRSam's Avatar
Click Here
Your ECU.
Old Jun 15, 2021
Colin42's Avatar
Check for loose bolts on the alternator
macmax2018
Apr 9, 2018 11:52 AM
JBAX91SI
15
Mar 7, 2014 06:12 PM
JackImpact
Jan 12, 2012 09:49 PM
hs992326
Dec 28, 2010 11:37 AM
navyedoc
15
Dec 25, 2003 10:34 PM
