ECU Fried 7th Gen cars have a Chronic issue - alternator bolts get loose and the loss of grounding will eventually fry the ECU
Ecu fried, now how to prevent new one from doing the same
Old Sep 4, 2019
shoemakerr's Avatar
shoemakerr is an unknown quantity at this point
My ecu fried last weekend, rpm guage went dead, temp went dead, cel is on, green key light is constantly flashing and runs rough doesn’t rev up past 2K if I were to guess, and no communication from code reader to computer. Limped it home (was half hour away) and just got a replacement today. I plan on taking it to dealership tomorrow to get keys reprogrammed...looking on info on how to make sure this won’t happen again. I’ve already ran 2 new ground cables one more directly from battery to frame and one from battery to block. Any help is appreciated, car is 01 civic si manual.
Old Sep 4, 2019
Slumpertcivic's Avatar
Re: Ecu fried, now how to prevent new one from doing the same
My suggestion would be to completely remove the alternator.
Using degreaser and wire brush and then Emory cloth or scotchbrite clean the physical mounting points on the alternator, bolts, and engine until you see shiny metal.
Be sure to properly torque the mounting bolts when you reinstall.
If your really concerned, install a separate ground strap using large band clamp ?
Old Sep 5, 2019
have you searched around? Loose alternator bolts is the most common causes of ECU fried (most likely the only one)
Old Sep 5, 2019
shoemakerr's Avatar
Never thought about a band clamp...thanks for the idea
kahxeg8
Aug 24, 2018 09:04 PM
bigdaddyclint
Nov 22, 2017 08:24 PM
jessemspears
ECU Fried
Dec 5, 2016 04:43 AM
shortkyle
ECU Fried
Sep 16, 2014 06:23 PM
mclean987
26
Jul 18, 2006 04:23 PM
