Who are using Eibach Pro Kit?
Old Jun 23, 2003
agungmeth's Avatar
agungmeth is an unknown quantity at this point
Hello guys,
Please post your car which are using eibach Pro Kit.
Thanks.
Old Jun 24, 2003
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
I'm using the pro-kit. its an okay spring. not much of a drop and ride quality is close to stock but it seems a little bouncier. also they are kinda expensive??.. and because of the nasty road conditions in NE, two of my shocks are leaking.. but it doesn't really matter anymore cause my Tein SS arrived yesterday.
Old Jun 24, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Sounds like you are on stock shocks. That is why you had a bouncy ride and why they leaked. If you get the pro-kit get the Koni's too!
Old Jun 24, 2003
yeah i don't trust the koni's, from what people have been saying about rear perch's breaking.. and the installation of the front's, just sounds like a pain in the arss, that i don't want to deal with. so i went all out and got the Tein SS..
Old Jun 24, 2003
bobbyd's Avatar
Good choice. I want the Koni's but like you said. More trouble thanthey are worth. Let us know how you like those Teins!
Old Jun 24, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
i just ordered my pro-kit yesterday
Old Jun 24, 2003
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
i have a prokit on my car. Its decent but i generally like a lower drop. It gives you a little bit better gap and handles better also.
Old Jun 25, 2003
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
Pro-Kit with 215/45/17s...
Old Jun 25, 2003
skivic's Avatar
skivic is an unknown quantity at this point
The pro-kit are alrite, gives you a slight drop and handles better. The ride will be more bouncy if you use it with the stock shocks. Overall its ok. If you want a lower drop, i think you should opt for the sportline..though its a little bit stiffer then the pro-kit. Thats if you only want to use eibach springs.
Hey brothersound, hows the ride with your new tein ss compare to your ex-setup (pro-kit with stock shocks)?? Ive ask in other post before whether the tein ss is gd...and i have made up my mind to get it. Just want to know what kind of ride i be expecting, as im also using pro-kit with stock shocks and plan to get the teins soon.
Old Jun 26, 2003
Actually I haven't Installed it yet, probably doing it this Friday & saturday.. and I can't wait. I'll let you know as soon as Its installed and I've had my fun with it.
Old Jun 26, 2003
tdog's Avatar
tdog is an unknown quantity at this point
I installed Eibach/Koni sport over the Tein>>
Why you ask?????
I wanted the best handling with a smooth ride.. (Different strokes for different folks)
I didnt like that every time you change the ride height you would have to get you alignment done!!!!
I installed The E/K myself it took 2hrs It was pretty easy as long as you have the tools....
Ill post a picture soon with Oem on a 2002 Civic 4Dr with E/K Suspension
Old Jun 26, 2003
skivic's Avatar
Ic..heheee. Alrite then, let us know hows the tein ride over your current setup when you are done installing & tested it
Tdog, did you have any prob running your car with konis?? Ive heard sooo many bad things about it (on 7th gen cars only anyway). And the way the front shocks have to be hack to fit in the konis doesnt sound assuring.
Old Jun 26, 2003
tdog's Avatar
skivic.... I had no problems at all to be honest.
Ya hacking the front strut does seem to bring a question,
let me run through real quick the procedure......
You take the Oem strut drill a hole on bottom (it gets a little messy)
bore out the hole so when you put the Koni in it will bolt to the strut housing.. Now you cut the top of the strut to take out the shocks piston. Bore out the openning a little, smooth it out and then just slide the Koni shock right in.. Its a good fit, no play inside, (thats good). Put everything back together just the way it came apart and install, thats really all on the fronts.....
And the back are CAKE....
Old Jun 26, 2003
skivic's Avatar
Ic, you had no prob running with the konis huh. Read fr other post, that the front shocks make a lot of noise and something about the rear rings snappin/crack. Thats why i was wary of fitting in the yellow konis, and now have opted to go with teins coilover. And the part where we have to put in the konis inside the stock shocks (front)...spells 'potential problemo'. How long have you been using it??
Old Jun 26, 2003
tdog's Avatar
On my car the only noices I hear is from turning the wheel all the way left, but I havent had the chance to get it aligned... I installed the E/K bout 2 monmths ago.. What I heard is you will have noicez in the begining, but az soon as their worn in, its quiet..
With the rear ring snappin' I believe that person has coilovers or has it lower than 1.5"..... With the set up I have Im not worried bout that.
Old Jun 29, 2003
skivic's Avatar
Ic...just 2months huh..hmm. Well, if any problem arises on your current setup, let us know , for the time being...i think i will stick to tein ss as my 1st choice, followed by koni-eibach. Still have to save up some $$ 1st though
Old Jun 30, 2003
well my friend & I finished Installing My Tein SS over the weekend. the install went pretty smoothly. we took our time though, we greased up every single bolt and a lot of the suspension parts and the camber kit. it was a pretty straight forward install. I made it a little easier for myself by buying the 2001 upper mounts and bearing rings, that made the front a complete swap. taking apart the rears to get the parts was very easy as long as you follow the diagram.
the overall ride quality over my (stock strut/pro-kit) setup, is better at the standard setting of 6 clicks back, and it gets smoother as you go more clicks back. Handling is much much better. it feels as though there's virtually no front & rear body roll. side to side is much improved also. right now i have the height set at exactly two finger gap, which is where i like it.
also, my stock driver side rear shock was blown and I've only had my pro-kit on for 9 months the others seemed okay.
also, Tein gives you way to many stickers with their coilovers I have no idea what I'm gonna do with all of them.
Old Jun 30, 2003
skivic's Avatar
Wow..that sounds very nice. 6clicks back and it rides better huh...fr what you have said, it seems handling performance all round have been improve. Yeh, thats the problem of having stock shocks with a shorter springs...tends to blow the shocks faster. I reckon mine will be on its way soon...to getting blown. I guess, i would definetly get the tein ss once i get the cash. And from what you have describe, i have lots of room to get a smoother ride..by turning back more clicks, incase i find it too harsh/hard for my liking That was my main concern of getting a coilovers...too hard for road usage. Oh, and its gd tein gave a bundle of stickers..the logos kinda cute...hahahaaa.
Thx bro for your 'review' on the teins...
Old Jul 13, 2003
dragoon's Avatar
I have prokit, I'm installing CGodwin3103's Ground Controls into my car this Saturday though, so bye-bye stock shocks
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
Viczhou
Sep 2, 2015 07:55 PM
