Problem with KONI's
Old Jun 4, 2003
rainsoni's Avatar
rainsoni is an unknown quantity at this point
Problem with KONI's
I have had my civic for 2 years and I have had my suspension setup for a year now and I am just now having a very anoying problem.
I am running ground control coil overs and koni yellows
This first happened on the highway. I hit a bump and felt the rear end sag. I pulled over had the car towed and found out that the c-ring that holds the lower spring perch on had bent and broken. I called koni and got a new c-ring and installed it just as I had before. And after a short time the same thing happened again. What is causing this.
It seems to me that the little c-ring is not adequate to take the loads that the spring perch sees. It apears to definately be the week link.
Has anyone else had this problem. What was your solution (with details)? Did I do part of the instalation wrong. Please help
p.s. I searched and found a thread that mententioned a problem like this but it was never resolved.
Old Jun 4, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Moving to suspension forum.... you will get better answers here.
Old Jun 4, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Try searching around...I believe this is a common problem/complaint about Konis but I dont want to say for sure because I dont have them.
Matt
Old Jun 4, 2003
Mbow's Avatar
Yea, I bought some and then sold them because I didn't believe in the strength of that c-ring. I posted pics and pointed this out in a thread months ago.
I wouldn't trust that c-ring for nothing.
Old Jun 4, 2003
rainsoni's Avatar
if anyone has a solution that they have tried I would appreciate it. I just don't understand how I didn't have a problem for a whole year and now all of a sudden I am having problems
Old Jun 5, 2003
flotsamm's Avatar
Sounds like the ring got weak over time and just failed to support the weight. I think someone said they had their clips welded on to fix this problem? Not sure..
Old Jun 5, 2003
VNlilMAN's Avatar
The Standard One
get the gc/koni adapter. that should help beef up the perch, if not ya you can always try and weld it on.
Old Jun 6, 2003
Cisco88's Avatar
Cisco88 is an unknown quantity at this point
We encountered the same problem that you had....
Koni sent us a replacement C-ring.....I don't think it will hold...
What setting are on your rears?
Old Jun 6, 2003
dezod's Avatar
7thgen Power Maker
Not the first time I heard this complaint.
Old Jun 9, 2003
Robthe54's Avatar
Robthe54 is an unknown quantity at this point
i've had the same problem with my koni's using progress springs...
the problem is simple, our cars are too low...
the spring perch will last a lifetime with the stock height/weight springs...
there is a phenomenon called "coil bind" which is where the spring gets so loaded that all the coils are touching... at this point it's no longer a spring, but a tube of metal
if the spring bottoms out before the shock, then everytime you bottom the car out it's like taking a hammer to that "tube of metal" (that should be a spring) sitting on the spring perch...
the solution(s) to your problem are simple, albeit you won't want to hear them...
a: get some springs with a 1 (or so) inch drop for the rear...
or
b: weld that sh_t
although i *think* there is one other way... if someone could make a solid ring that fit on the tube of the shock that was held up by the c-clip and was about 1/2inch think and held the perch i think this would stop the perch from bending enough to eff with the c-clip
Old Jun 12, 2003
Robthe54's Avatar
update:
i just received replacement parts from koni. the rings are made of a diff. material, and the spring perches SEEM to be thicker...
hopefully these won't break...
Old Jun 12, 2003
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Yeah...I got my Koni's like a year ago...and well my c-ring....broke...cisco-88 is the witness to that...well luckly the perch got stuck in the groove where the c-ring sits...cuz ****..my car would have droped to the ground....all in all...the c-ring that koni gave for a replacement is great....seems to be a better material....
Also..my ground controls somewhat bent...ugh..soo not cool....
Old Jun 13, 2003
tekgnosis's Avatar
Ask me about your mom.
is koni the only shock that this will happen to?
coil-bind really sucks. I just have goldline springs and stock shocks. I was putting on all my swaybar/tiebar/strutbars this weekend, and I could tell that all the coils at the bottom touch everytime I hit a bump. Riding on stock shocks is OK, but not if you have an 01/02...honda started carrying a different manufacturer for struts because they needed to get so many replaced! man, that sucks.
anyways, it wore the paint off the springs, and started to rust out the freakin springs. man, I'm pissed.
so, I ordered the Tein SS system
Old Jun 13, 2003
CivicHX01's Avatar
i just got koni's recently and hopefully these new ones came with the "new" c-ring... i've had 2 heavy guys in the back since i've installed them and they've held up so far....
/me knocks on wood
Old Jun 15, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Hmmm...
I have had my Koni Yellows on my rear suspension for over a year as well. However I have run into no problems. Would it maybe have to do with how low the car is? I have 2.0" drop on the front and 1.8" drop on the rear of my car and even lower in the past (changed springs). I have also hit some nasty bumps. ANyone have more input?
Old Jun 25, 2003
Hazard5's Avatar
Hazard5 is an unknown quantity at this point
sivion..wat kinda springs did u use? that's the drop i want
Old Jun 25, 2003
deeznuts's Avatar
deeznuts is an unknown quantity at this point
I've got koni yellows on front and rear with skunk2 coilovers. I used the skunk2 adapter ring and haven't had any problems. I have the car lowered about 2.5" all around.
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
cukaracha
May 16, 2015 07:36 PM
SneakerPimp
Dec 7, 2001 07:09 PM
