Newbie suspension questions?
Old May 7, 2003
bboyclumsy's Avatar
bboyclumsy is an unknown quantity at this point
Im only looking to spend around 1200 with install on everything for suspension. What would you guys recommend me to get. I was looking for a neuspeed front tie bar, a set a sway bars ( Not sure what combo is the best), springs and struts or H&R cup kit. What would you guys recommend, like what brands and setups?
Also what order should i buy the stuff in. I have like 500 now to spend.
Mike
Old May 7, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
get Tein coilover either Tein Basic or SS, cuz Tein is Japan biggest suspension co. other thing is that Honda is Japanese car.
Old May 7, 2003
VNlilMAN's Avatar
The Standard One
h&r cup kit isnt out yet. or atleast last time i checked it wasnt. expect to get new shocks eventually, you get to decide if you want to do that now or later.
if you get it now, konis are your only options and those run $550. this is excluding your spring. you can also get true coilovers that come with shocks for around $1000. but ya you only have a $500 budget now so either you can just stick with springs or lower your car later on when you have more money. i personally just decided to lower the car with springs untill my shocks blow. springs should cost around $200 installed. or if you can install yourself you save $80-120.
spring give you the best improvements. then sway bars.. i would try to get a 19mm RSX sway bar. might be able to find one for $50 with bushings are clubrsx.com. if you decide to go with a 22mm, your going to end up spending more as you will also need a tie bar and maybe new endlinks. reason being, the 22mm might be too stiff where your endlinks will rip off.
neuspeed front strut bar. nice cheap, solid design. like $100.
Old May 7, 2003
civicvtec1ps's Avatar
Search and Learn
neuspeed sports 150
koni yellow 550
neuspeed front strut bar 100
spc camber kit 130 there GB right now
rsx sway bar 19mm with bushing new 100, used 60
ebay low tie bar 20 bucks .
i paid 60 bucks for used sway bar with bushing at www.clubrsx.com
installation will run 100-200 depends on shop and you $ for alignment.
i went with tein ss. installation was pretty stright forward. installed with my friends so i saved money. i didnt even get alignment yet
EdGasket
40
Nov 27, 2015 11:11 AM
Strycker
Aug 2, 2015 08:40 PM
JKWood
Jul 28, 2015 03:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Civic65
Jul 19, 2015 10:13 AM
